- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Powerline 1000 with Powerline 1000 WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have bought the Powerline 1000 (2 devices) and that is working fine to extend my wired signal to another room.
3 questions:
1) I want to extend to other rooms, if I buy 1 more box (2 devices), can I use those for 2 more rooms, so have 1 for the router and 3 for the other rooms - ie are they all compatible?
2) I also would like to extend the WiFi as the signal is poor at the top of the house - if I buy the Powerline 1000 wifi box (2 devices) will that work in the same way, so the WiFi devices will be compaitble with the one alrady by the router, and one can be used in another room?
3) will the WiFi use the same SSID as the current, so extend it on the same network, it will it create a new SSID?
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Powerline 1000 with Powerline 1000 WiFi
Yes. Just add more plugs.
Remember, when adding new plugs to an existing network, you need to follow this advice:
>>> Adding a powerline adapter to an existing powerline network <<<
You need just one plug connected to the router.
Yes. Buy a powerplug bundle with a wifi access point thrown in.
Up to you. You can give the plugs whatever SSID you like. Generally people recommend using different SSIDs.
Does that matter? Most wifi clients can automatically switch between SSIDs as you move around.
