Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Powerline 500 Nano and netgear gigabit switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-01
02:07 PM
2012-09-01
02:07 PM
Both devices are netgear, powerline worked fine but previously had the signal for one split between a 10/100 switch. Wanted to see if I could get a faster connection out to the tv since the powerline was 500 Mbps so I got the netgear 5-port gigabit 10/100/1000 Ethernet switch but when the powerline is hooked up to it starts constantly flickering and the connection drops in and out.
Do these two devices not work together or would I just need to do a total reset to possibly get them communicating?
Message 1 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-28
12:09 PM
2012-09-28
12:09 PM
Re: Powerline 500 Nano and netgear gigabit switch
I seem to have the same Problem. Is there any Solution yet?
For me, the powerline adapter connects either with 100MBit stable or with 1GBit continually dropping and reconnecting.
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-28
12:15 PM
2012-09-28
12:15 PM
Same problem here with Netgear switch. Sometimes the adapter connects with 100Mbit without obvious reasons. Then the connection stays stable. But reconnection the cable, every time the two devices try to use 1GBit, the connection drops every two seconds, the re-establishes, then drops and so on.
Any solutions yet?
Any solutions yet?
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-04
09:41 PM
2012-11-04
09:41 PM
Same issue here. It happens when I put multiple streams through the connection every time without fail. It almost looks like the nano is resetting itself.
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-05
11:34 AM
2012-11-05
11:34 AM
Agm wrote: Both devices are netgear, powerline worked fine but previously had the signal for one split between a 10/100 switch. Wanted to see if I could get a faster connection out to the tv since the powerline was 500 Mbps so I got the netgear 5-port gigabit 10/100/1000 Ethernet switch but when the powerline is hooked up to it starts constantly flickering and the connection drops in and out.
Are you also experiencing intermittent connection on the devices connected directly on the NETGEAR 5 port switch or just only on the device connected on the powerline?
You can also try to reset the powerline or connect both powerline on the same room wherein you have your switch and check if the connection will still drops.
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-06
07:03 PM
2012-11-06
07:03 PM
user id's and passwords
I am trying to change my setting from a wep to a wpa, but when I enter my user name and password, it does not connect. How can I access this? any way to by pass this?
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-08
10:14 AM
2012-11-08
10:14 AM
May I ask what is the exact model number of your NETGEAR switch?
Message 7 of 7
Announcements
