× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Powerline PLP1000 not doing gigabit
markwilliams59
Hi All
I have 2 x PLP1000 and a performing network but I can't get it to run at 1Gbps only 100Mbps.
Both the PLP are connected to GS305E gigabit switches. The switches are running fine.
The issue is PLP to PLP.
Why can't I get gigabit throughput between them?
Any help appreciated.
Model: PLP1000|Powerline 1000 + Extra Outlet
Message 1 of 3
Guru
Re: Powerline PLP1000 not doing gigabit
Powerline numbers are even more inflated that wireless numbers in my opinion. The good thing about them though is they don't fluctuate a lot. so the connection you get, is usually solid/reliable.
If you read reviews on 1000mbps powerline devices, even in an optimal configuration, they won't hit their advertised speeds. Then add in "non-optimal" like a home and put the powerline devices on seperate circuits or with devices that cause interference and their speeds drop further.
I'd recommend reading a few performances tests on powerline.
Here's one for netgears PL1200 (a little better device)
https://www.smallnetbuilder.com/archives/lanwan/lanwan-reviews/32717-netgear-pl1200-powerline-1200-r...
Message 2 of 3
markwilliams59
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 652 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
