× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Weak Wifi Signal
mrcjr24
Follower
Weak Wifi Signal
I just purchased a Powerline 1000 for my 2100 sq ft home. It's an old Victorian so the walls are plaster and therefore very thick. All 3 of the green lights are active on my Powerline Adapters, but the wifi signal still fades in and out in the rooms that I needed a boost in. Any suggestions on what could be wrong or do I need a stronger Powerline Adapter altogether?
Model: PL1000|PowerLINE 1000 adapter
Message 1 of 2
Accepted Solutions
Re: Weak Wifi Signal
The PL1000 on its own will do nothing for your wifi. It is an Ethernet plug. The PLW1000 does wifi.
A Powerline wifi access point has a limited range, like all access points. You may need several strategically placed around the house.
Message 2 of 2
All Replies
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1470 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
