Reply
Where to login to change Wireless Extender Password? Netgear XWN5001
ConsultMcClain
Follower
Hi,
We have this netgear extender with the default username and password. We'd like to change it but cannot seem to find the backend to change it. We've tried www.mywifiext.net, www.netgearextender.net and neither are working.
We went to the Netgear Genie, found the wifi connection and clicked on properties to type in the IP address into the browser, no such luck,.
Does anyone have any thoughts on this one?
Thanks!
Model: XWN5001|Powerline 500 WiFi Range Extender
Message 1 of 3
clithes
Prodigy
Re: Where to login to change Wireless Extender Password? Netgear XWN5001
You nearly had it.
Find the IP address from the attached devices of your router, then use an internet browser to access the GUI using that IP address.  If you connect to the wi-fi channel from the adapter (not your router) then www.mywifiext.net should work as well.
Mine is at 192.168.0.244 (yours will be different).   Once i've typed this in the brower address I get the GUI.  You will be asked for a username and password, which are admin and password unless you have already changed them:
From here you can change the adapter's settings
Hope this helps
Modem: Vigor 130 | Routers: R7800, R8500 & R9000 | ISP : Plusnet Unlimited Fibre Extra
Powerline: PLP1200x4 PL1200x6 | WiFi Extenders: PLW1000 & XWN5001
Switches: GS105Ex2, GS105Ev2, GS108Ev2, GS305
Message 2 of 3
clithes
Prodigy
Or you can go back to the Netgear Genie, select Network Map and then click on the powerline symbol in the top-right (this often takes a minute or two to appear)
Then right click your XWN5001 adapter and select 'Configuration'
This will take you to the GUI as well
Message 3 of 3
Discussion stats
  • 2 replies
  • 12086 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
