Reply
XAV5001/5004 low throughput
dnd
Luminary
Luminary
hi,
anybody having throughput problems with the above combo? powerline utility shows throughput of 275-350Mbps (varies), but real-world throughput is around 7mbps. what gives?
Message 1 of 4
rallison
Luminary
Re: XAV5001/5004 low throughput
Hi DND,
Yes, very disappointed with XAVB5001 Performance.
Purchased on Netgear Quality Promise to replace LAN over Power adapters supplied by ISP.
Units have failed to meet expectations with speed of 5-21 Mbps RX and 10-80 Mbps TX.
Very little support from Netgear on-line Technical Team: ‘lots of talk and no action’.
Robin
:mad:
Message 2 of 4
xavierf
Luminary
I had the same problem with XAVB5501 max 80 Mbps for RX and TX. :mad:
Message 3 of 4
dnd
Luminary
Luminary
actually i sorta fixed mine by unplugging and replugging the xav5001. before was real-world throughput of around 7Mbps, afterwards was 53-4Mbps. the utility showed lower throughput at around 230-250Mbps, but the real-world was way higher.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 6150 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
