cuypersk's avatar
cuypersk
Follower
Sep 11, 2011
XE104 powerline compatible
I 've used two XE104 powerline adapters.
One is used at the source (broadcaster modem).
The other, two Ethernet ports ares used (laptop and fixed PC).
Now, I want to create a third point: Smart DTV and digibox (digital TV). Unfortunately, the XE104 is no longer available.
Which type should I buy that is compatible with my two XE104?
Thanks, CK
