- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo RND2000 V2
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Can I move disks with data from an older ReadyNas Duo V2 to a newer chassie?
(The older have a power fault.)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello @Keyman42
Welcome to the Community
If the new NAS is exactly the same model as the old one, then you can transfer the disks in the same order to get access to the data, provided the HDDs are healthy.
However, if you wish to transfer the disks to a different model, then you should get in touch with Tech Support for the data recovery. See this KB article as an example, should you wish to migrate to the new OS 6.
Before transferring the disks or performing any other operation, we recommend ensuring that you have an updated external data backup.
With ReadyNAS, it is essential to keep an external backup of the data, to ensure their safety.
Kind Regards,
Erika
NETGEAR Team
____
Gentilmente clicchi KUDOS
se ha trovato la risposta utile e ACCETTARE COME SOLUZIONE se opportuno.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello @Keyman42
Kind Regards,
Erika
NETGEAR Team
____
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: ReadyNAS Duo RND2000 V2
It is not possible to find an exact type. ReadyNAS Duo 212 is availibel. Can that work??
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello @Keyman42,
the model RN212 is an OS 6 NAS, so in order to migrate the disks of your RND2000v2, you should contact NETGEAR Tech Support.
Please refer to the KB article "ReadyNAS: Migrating disks from RAIDiator 4.1 or RAIDiator 5.3 to ReadyNAS OS 6".
Kind Regards,
Erika
NETGEAR Team
____
