- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
One or two issues....
You: Hi @Martin Nilsson, Yes, that's what I meant. Is the R8000 in AP mode when you follow these instructions? So, if it's not, it's in router mode. Not to have issues, your ISP modem should be set up in bridge mode. If it's not, you have 2 routers on your network and it can create double NAT issues. Valérie, Team NETGEAR
Me: Hi Valérie, I've removed the ISP modem entirely. And my network cable is connected directly to my R8000. Rgds, Martin And thats basically as far as we came. I'm still experiencing lots of troubles with router rebooting frequently, not all possible connections showing (should be 3. The 44, 44 5g1 and 44 5g2) and as it is right now. All lights are there but my connection on the phone only show the 44 5g1. But won't connect. I've even received the error message "wrong password" from time to time... Any way we could sort this out u think..? Kind regards, Martin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: One or two issues....
Hi again @MartinN,
And welcome to the NETGEAR community!
Ok, so basically if you removed the ISP modem, I supposed you're with fibre?
Have a nice day,
Valérie D
Netgear Team
____
Cliquez sur KUDOS si ce post est utile et marquez le comme SOLUTION ACCEPTEE
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi and thank you!
Thats right. I'm on fibre and removed the ISP modem and hooked up the r8000 and then the troubles began....
Kind regards,
Martin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi again @MartinN,
Thanks for the confirmation.
Then, it should be good to begin with asking your ISP which technical specificities are needed to remove their own router and replace it with a NETGEAR one. Like, some ISPs need special DHCP options.
Knowing this, I will be able to look into the R8000 specificities and understand where the issue is and how to solve it.
Have a nice day,
Valérie D
Netgear Team
____
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Alright @ValerieD
Called my ISP and asked them if there were any specifics needed with the reply that it wasn't, besides that the DHCP was... Enabled? Well, anyways it was. Because he could test that from his side and he had connection with the router and didnt get any errors messages back.
Kind regards,
Martin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi @MartinN,
Ok, then could you tell me what if the firmware version installed on the R8000?
I didn't ask you, but did you switch to fibre and install directly your R8000 as new, or were you using the R8000 before switching to fibre?
Have a nice day,
Valérie D
Netgear Team
____
