Reply
RBR50 WIFI instable V2.7.2.104
tc_vbc
Hi
My RBR50 (and one satellite, wired) has lately started "rebooting/-starting WIFI.
It used to be stable as a rock but now uptime seems to get to max 15-20 minutes then it drops then reactivates 😞
Anyone else with solution or same behaviour after V2.7.2.104???
Check neigbour wifi's, fixed channel for wifi now, by all means rebooted (and looked better after that but reoccured again 😞
br /Thomas
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
IoannisDM
NETGEAR Employee Retired
Re: RBR50 WIFI instable V2.7.2.104
Hallo @tc_vbc,
herzlich willkommen in der Community! 🙂
Könnte ich Sie darum bitten Ihren Beitrag auf Deutsch zu verfassen, damit alle Nutzer der deutschsprachigen Community den vollen Inhalt verstehen und gegebenenfalls diesen als Lösungsansatz nutzen können.
Jedoch wenn Sie bevorzugt auf Englisch schreiben, würde sich für Sie am besten die englischsprachige Community anbieten.
Vielen Dank für Ihr Verständnis!
Mit freundlichen Grüßen,
Ioannis
NETGEAR Team
____
Klicke auf KUDOS, wenn du diesen Beitrag hilfreich findest, und markiere ihn ggf. als AKZEPTIERTE LÖSUNG.
Message 2 of 6
tc_vbc
Ehhh??? I posted in english??
Message 3 of 6
IoannisDM
Hi @tc_vbc,
firstly I want to apologise for my mistake about the languages!
After you installed the latest firmware version 2.7.2.104 did you only try a reboot or a factory reset as well?
It would be recommended for you to perform a reset which in return could cause all the features to be available again.
Ioannis
NETGEAR Team
____
Message 4 of 6
tc_vbc
Hi,
I have only performed multiple rebots after upgrade, last reboot have kept all fine for appr 24h now 🙂
If WIFi starts going up and down again I test with factory reset
Thanks for the hint
BR Thomas
Message 5 of 6
IoannisDM
Hi @tc_vbc,
we are glad to hear that it is working! 🙂
If there is some change or update we would appreciate your feedback!
Ioannis
NETGEAR Team
____
Message 6 of 6
Discussion stats
  • 5 replies
  • 1852 views
  • 0 kudos
  • 2 in conversation
