Sappa
Mar 03, 2023Follower
Mod Ex6470
Bo jour je n arrive pas à connecter la WiFi sur le routeur
1 Reply
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
