Antworten
Internet is not working.
Tushard3094
Follower
I have the Netgear r6220 AC1200 router. The connection from the modem to the laptop is working perfectly well but when I am connecting it to the Router and then connecting my laptop with LAN or Wifi, it’s not working. The laptop gets the connection of the router but there is that yellow exclamation mark and the internet doesn’t work. Non of the devices is able to connect to the router.
Please do let me know if anyone knows a solution to it
Thank you
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Nachricht 1 von 2
Slas
NETGEAR Employee Retired
Re: Internet is not working.
Hello @Tushard3094,
and welcome to the NETGEAR community.
Check the IP configuration on your laptop.
Your laptop must be in the same IP range as your router.
Does the R6220 work in router or AP mode?
Which modem do you have?
Best regards,
Slas
NETGEAR Community Team
Nachricht 2 von 2
Autoren, für die die meisten Kudos vergeben wurden
Diskussionsstatistiken
  • 1 Antwort
  • 1074 Aufrufe
  • 0 Kudos
  • 2 in Unterhaltung
