Reply
Follower
Best router configuration?
Hey guys, thanks in advance for taking the time to look at my thread, and that any advice will be greatly appreciated. For starters, i'm new when it comes to working with routers and networking equipment.
I have a lot of devices that connect to my home network, and i thought the old router i had wasn't cutting it, so i got the R6300 thinking it would boost my speed and keep a steady connection. I did a speed test on my old router and compared it with the new and the results were basically the same slow speed as before.
My question is, how do i maximize the settings of my router for gaming with an xbox, and media streaming across the network?
Tutor
Re: Best router configuration?
Who is your ISP?
Is it cable or DSL?
What type of cable/DSL modem are you using?
1xR6300 V1 - V1.0.2.36_1.0.28
Luminary
For one buying new router will not make Internet faster than your ISP provides do you need detail what is the issues in what ground
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Like you, I was curious to see if the R6300 could boost internet performance over my old WNDR 3700r1, which it did not, but that's because the limitations of my ISP. did you find your answer?
main router:R6300v1,/ switch: pro safe GS105v3./ISP: Cable One /OS:Windows 7 64x SP1
Discussion Stats
  • 3 replies
  • 2402 views
  • 0 kudos
  • 4 in conversation
Top Contributors
