Reply
Block Devices from Internet
Is there a way I can temporarily block certain devices that are connected to the router from using the internet?
Like my brother, he isn't supposed to be on xbox after 8PM, and my Dad needs me to enforce it (since I'm the network admin in our house). Can I manually block his xbox from accessing the internet either at a certain time, or just by manually restricting it?
Tutor
Re: Block Devices from Internet
I know you can sechule a sutdown of the entire internet but I dont know about speicific devices.
1xR6300 V1 - V1.0.2.36_1.0.28
Luminary
You have to setup specific ip for Xbox using address reservation working the dhcp range under router GUI, lan setup
Then you need to make block services with schedule
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I do set up every device to keep its ip once it connects under the lan setup page.
Luminary
Yes..........
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Hello,
Maybe you could be kind enough to help me also. I'm pretty much trying to figure out the same solution as the other person regarding his Xbox....
I followed your instructions on how to reserve ip adresses for all devices, then I can shut down services according to planning, but is there a way to set different plans ?
Like allowing a device to access the internet up to a set time on weekdays, but let's say midnight on weekends ? and different time slots for different devices on the network ? The only thing i'm seeing so far is by installing bypass accounts on the opendns website, is there a way to manage it with the router' firmware?
Thanks in advance for any information
Luminary
Use parental control or use block service I'm the router interface
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Maybe my question was not precise enough.
Is there a way to set different tome plans for different devices ?
For example device x 192.168.1.2 gets shut down from all services at 8.00 pm
device y 192.168.1.3 gets shut down from all services at 9.00 pm
device z 192.168.1.4 gets shut down from all services at 11.00 pm
..............on sunday to thursday, but get a different time allocation on fridays an saturdays?....let's say till 2.00 am?
The way i'm seeing right now, i can set only 1 time plan from the router, wich would apply to any and all devices that I would list in that only available plan.
And then I could add a time block in the open dns web service, wich would apply to all devices.
I feel i'm forgetting something, there must be a way ?
Luminary
You need to install parental control on each device
Netgear.com/lpc
Setup up each user with correct schedule
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Hi just wondering if you knew how to log into the bypass accounts from other devises like ipads, iphones? i can work it out on the main laptop but i am after this parental control for the kids and they only use ipads not main laptop. any feedback would be great thanks
Retired_Member
Be a parent tell them the rules if they break them take the toys away. It's that simple.
Luminary
For mobile iOS try this. It is not free service but perfect for it
http://www.mobicip.com/
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Will this work with a pc labtop?
My step daughter is here for the summer and she loves to get on the computer. Even when she is told she is not allowed.
We really need to block just her laptop at certain times or when i leave the house.
Luminary
Go to the website and read up if you are asking to my last post
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Hello, Does Live Parental Control block Skype? Because my son uses Skype to chat with his friends. I know Live Parental Control can block access to Youtube and Facebook but will it block instant messenger type applications? What about an iPod, is this controllable? Thanks in advance.
Discussion Stats
  • 14 replies
  • 6329 views
  • 0 kudos
  • 8 in conversation
Top Contributors
