Reply
Guest Wireless
I have an R6300 with guest wireless enabled. Is there a way to give limited access to a guest wireless connection?
To be specific, I have a Netgear ReadyNas that has video on it. I would like to be able to stream that video to a guest wireless connection over the LAN, without having to incur internet bandwidth.
Is this possible somehow?
Clifford.
Luminary
Re: Guest Wireless
No.. you either allow all on guest or none
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Re: Guest Wireless
Thanks Jim. Not what I was hoping for, but it saves me a bunch of time.
Luminary
Re: Guest Wireless
If you have ReadyNAS http://netgear.com/landing/storage/for_business.html#1
Now you can have little more permission but not with READYSHARE ( NOT ReadyNAS) on R6300
Using True NAS will have user/pass within GUI of NAS or you can even bring AD server to control the user account instead of rely on guest wireless that limits.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: Guest Wireless
Yes, I could do that. I have a bunch of PC's in the house that are not password protected, and I don't want to put passwords on them. Giving a guest lan access would expose that information.
Would it work to put the readynas in a dmz? Would that allow video streaming traffic to stay within the lan when streaming from a guest wireless?
Luminary
Re: Guest Wireless
I don't think so.
Guest and primary setup on vlan internally to isolate
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: Guest Wireless
I suspect you're right.
Thanks for the info, I appreciate it.
Discussion Stats
  • 6 replies
  • 1776 views
  • 0 kudos
  • 2 in conversation
Top Contributors
