Reply
How to assign Static IP Addresses to certain Devices
I recently purchased the R6300 and want to set up time limits for when my kids can access the internet, while not limiting the devices my wife and I use. I figured out, by reading the manual, how to block a range of IP addresses from a specified service (Http) according to a schedule. Because IP addresses are randomly assigned, I need to make sure my kids devices are assigned IP addresses within the limited range but the adults are not. I am unable to find the procedure in the user manual. Technical support does not seem to understand this. Is this possible??
Thanks
Velo
Prodigy
Re: How to assign Static IP Addresses to certain Devices
The probable reason why tech support cannot understand is that you are using the term static address incorrectly.
You cannot assign a static address to a device using the router - any device that gets it's address from the router is doing so using the DHCP (Dynamic Host Configuration Protocol), which means it's getting a dynamic address.
Static addresses have to be set at whatever device will have the address - assuming that you can configure a static address on that device, for example, I've never found a way to set a static address on my android tablet (mind you, I haven't looked very hard).
If you want the router to assign the same address to a device every time, you need to use what is called DHCP reservations, or reserved DHCP addresses - see if you find that in the manual. And - by the way - it will probably take your kids less time to figure out how to defeat your control, that it takes you to set it up.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Luminary
recently found cool service
http://www.mobicip.com
you might even like this better than tradition all ports blocking and time schedule
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Initiate
Although I do not have the router in front of it, all the ones that I've touched had the "static" ip option.
In short the Router identifies the MAC during the DHCP and assigns the device with this MAC a specific predefined IP, thus making it work as static IP. (not true static, but it works).
If you assign a device a static IP, but DHCP on router is not skipping this static IP then you will end up with IP collision, so not a good idea. If you go this route the easiest is to go to routers DHCP section and make it start at say x.x.x.20
the assign your "static" device Ip at x.x.x.10 or something less then 20...
Typically the option is somewhere under the DHCP section.
Luminary
simply two of doing this
static IP on DEVICE side must be outside of DHCP range
specific IP pushing to DEVICE side from the router must be use within DHCP with address reservation under LAN setup
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Prodigy
Do I really need to explain further? Do you really feel you need to further obfuscate the issue?
Let's call a spade, a spade.
It's either static - or it's not - if it's static, then it doesn't need a DHCP server - if it's dependent on a DHCP server, it's dynamic.
IF YOU'RE SETTING IT AT THE ROUTER IT IS NOT STATIC.
Well, it's a fixed IP assignment by MAC address. I used to do it all the time for printers on an ISC DHCP setup (when the admins didn't realize they could manually configure our RX printers).
What I do on my R6300 is set the dynamic range from 150-250, then assign fixed addresses below the dynamic range. You do this by entering the MAC address for the device (or turning it on and picking from a list) and assigning it a name and a fixed IP address. For this setup, you'd pick an address 2-149 or 251-254 (I'd use 2-149 ... start at 2 and work your way up).
Try to keep the fixed address assignments from colliding with the dynamic IP addresses - it's programmatically possible to prevent fixed addresses from colliding with dynamic assignments, but why put yourself in the path of the truck?
Luminary
When you use address reservation on router , ip you choose must be within the dhcp range
Only use outside the dhcp range when you setup static ip in each device itself
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Beg to differ, but I'm currently using a dynamic address range of 150-250, and DHCP has (per my instructions) assigned the device with my MAC address 192.168.1.13.
There can be no danger of collision if the fixed address assignments are out of the dyanamic range.
Luminary
If rules took out of dchp range for ip then that is fine bit just about all Netgear home end router should use with dhcp pool to function
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
DHCP is either on or off for a network - it's not just effective within a certain range.
The range you're talking about is referred to as the dynamic range (more properly dynamic list) - it's the list of addresses which the DHCP server can assign to clients requesting an IP address.
Internet Software Consortium DHCP can handle multiple ranges within a subnet - and it makes no provision for fixed assignments within a range. If ISC DHCP can't ping an address within the dynamic range and there's no active lease at that address, it will assign the address (even if there's a fixed assignment at that address). This can lead to collisions if the device is ever powered off. That's why you should always assign fixed addresses outside the dynamic range.
You can programatically exclude fixed assignments from the dynamic range, but that results in fragmentation of the dynamic range and multiple extents - and as the code gets more complex, the chance of bugs creeping in increases. Of course you could create permanent "leases" for each fixed assignment at initialization, but that has drawbacks as well.
The most prudent course is not to walk down the middle of the traffic lane - that way you don't have to count on every driver being awake and alert.
I don't know why nobody can explain this in these forums but I did figure it out.
1 - login to your router
2 - advanced tab -> setup -> LAN setup -> Add
3 - select the device you want to assign a static ip to
4 - update the ip
5 - click add, then apply
Prodigy
dubwha - if you had read the thread you'd have read the expanation - what you're doing is called DHCP reservation, not static addressing.
The essential difference is that static addresses can be used in the absence of a DHCP server, DHCP reservation only works if the DHCP server with the reservation is available.
Discussion Stats
  • 12 replies
  • 52221 views
  • 1 kudo
  • 6 in conversation
Top Contributors
