Reply
New Firmware: 1.0.2.36_1.0.28
I'm going to try this when I get home!
R6300-V1.0.2.36_1.0.28
New Features & Enhancements:
Added Turkish language support in GUI.
Added Russia WAN Wizard and Russian IPTV support.
Added 2.4g HT20/HT40 coexistence disable button so router can stay in HT40 to have higher link rate, even there are some wireless interference surrounding.
Change Web GUI display issue when radio is disabled.
Change MiniDLNA code base to fix SQL attack issue.
Added GUID partition table support.
Bug Fixes:
Fixed Broadcast Name on Router Status page displayed off when SSID Broadcast is enabled.
Javascript error displayed after fill in the Router's PIN number and click "Next" to start the WPS process on IE9.
Fixed 5Ghz Signal degrades or link rate drop after R6300 running after couple weeks in some noisy\interference environment.
To Install
Note: Do not upgrade the firmware using a wireless connection. Please perform firmware upgrade with “wired” or Ethernet connection only.
Write down all the settings which you changed from the default values, since you may need to reenter them manually.
Download using the button below to a convenient place such as your desktop.
Log in to the router using a Web browser. The URL is http://www.routerlogin.net.
Click ADVANCED tab > Administration > Firmware Upgrade.
Click Browse and find the file you just downloaded.
Click Upload. Do not interrupt the upgrade while the router does this step.
Important Note:
1. The upgrade process is completed when the on screen progress bar completes. If power LED light turns amber and blinking, power cycle the router to complete the upgrade.
2. If the upgrade progress bar on web GUI doesn’t display correctly during firmware upgrade, you can still check the status using Power LED. The Power LED should be blinking (amber) during firmware upgrade. After firmware upgrade is done and boots up the system, it changes to steady amber color.
Please DO NOT power off or reboot the device during firmware upgrade, otherwise, it may result to a corrupt firmware and cause the device not to work.
Tutor
Re: New Firmware: 1.0.2.36_1.0.28
Me Too!!!!!!!!!!!!!!
1xR6300 V1 - V1.0.2.36_1.0.28
Tutor
I will b installing this on Friday.
Also I will be testing this with the a6200 adaptor!
Apprentice
It feels faster than .21
4xR6300 AC1750 V1 - V1.0.2.78_1.0.58 whole house router+wireless. 51 devices connected.
1xWNDR3700 N600 V2 - V1.0.1.14 provides internet to my first floor and back yard
2xWNDR3400 N600 V1 - V1.0.0.50_20.0.59 running faithfully in a crowded apt building
2xWNDR3300 N600 V1 - V1.0.45 over 2 years since reboot
3xWRT54G/GS - DD-WRT what can you say about the legendary WRT54
DIR-615 vC1 3.13NA - great little router
DIR-655 vA3 1.37NA - RETIRED never worked right with OOMA
EDIMAX EW-7416APn v2 1.13
all NETGEARS are factory recertified except 1xWNDR3400
HOW TO: My router firmware upgrade instructions:
http://forum1.netgear.com/showpost.php?p=425691&postcount=4
HOW TO: Reinstall the firmware on a router without the setup CD recovery tool
http://kb.netgear.com/app/answers/detail/a_id/19841/~/reinstall-the-firmware-on-a-router-without-the-setup-cd-recovery-tool
HOW TO: Extend AP on separate LAN
http://forum1.netgear.com/showpost.php?p=479421&postcount=5
HOW TO: Extend AP on the same LAN
http://forum1.netgear.com/showpost.php?p=481991&postcount=2
Apprentice
Upgrade Notes:
1) Latest FW seems to be working good.
2) I initially upgraded using a wired machine. I used the 6300's administrative page to do the upgrade
3) After the upgrade I had internet access for a short period of time, but then lost internet access on all of my machines
4) I then performed a Reset to Defaults | Upgrade | Reset to Defaults and rekeyed my settings (reservations / port forwards, DHCP range, etc.)
5) I noticed that my machines weren't picking up the reserved DHCP's properly and I had lots of IP conflicts after making reservations. I have 44 devices and some get IP's reserved, some are static, and some just get whatever DHCP hands out.
6) Unlike previous FW upgrades, I had to power on/off or reboot many of my devices in order to get the proper IP's handed out to them, they didn't seem to get reset on their own. This was after powering the router on/off a couple times.
Once I got through those steps, the new version has been working good. I guess the only recommendation I would make is to do the RESET TO DEFAULT upfront before starting the upgrade and it will save a step in the process.
Tutor
Ok
Just installed my new Netgear A6200 WIFI USB adapter and i am now getting 585 Mbps on 5G.
I am now going to install the new firm ware and see what that does.
Connections are at the same speed although the throughput seems to be more stable. Not as many hiccups. It is still suffering from the Xbox problem though. Shelving it & going back to my WNDR3700v2.
They better get their act together with this thing. I'm starting to smell a class action suit coming.
Tutor
OK now after the upgrade I am steady at a signal of 585Mbps on 5G. However this is with the new A6200 wirless adaptor.
Novice
So far so good. I updated the firmware yesterday morning and so far the 5GHz band has been stable. I have also noticed that my neighbors networks show stronger signals than they have before upgrading the firmware.
I'm not going to be sure this is really the fix until I see several days of 5GHz stability. It's been 4 months since I purchased this router and have not had a good experience with it up to now. When you purchase a product you shouldn't have to wait 4 months to have the useability you purchased it for in the first place. I just hope this fixes the problem once and for all.
Quick question. What colors are the bottom LED's suppose to be with the new firmware? Or what are your user experiences?
Seems to be the plight of the early adopter. Everything is sold in beta and we pay top dollar and after half a dozen firmware upgrades it is a finished product and the price begins to drop and the cycle repeats itself.
Tutor
Can you at least tell us what Mbps your are getting?
Steady means nothing with our that.
Tutor
Yellow or yellow oragneie
Novice
Around 38 Mbps down and 7 up..That is basically around the same speed I get hard wired and has always been pretty consistent when I was able to get online. My problem has never been the speed consistency, just that I was able to connect in the 5GHz band until the signal degrading would not allow me to connect in the 5GHz band at all in certain areas of my house.
Tutor
RIGHT CLICK ON YOU WIFI ICON SELECT open network sharing cemter
click on the wireless icon and tell us what your speed is.
Novice
300.0 Mbps
m4p Aspirant
I just updated to new firmware (I was running 1.0.0.90.1.0.18). I also have a second R6300 I use as a wireless bridge so I updated that as well.
Before update, connection from bridge to router on 5Ghz band would usually be 525Mbps. After updating both routers, connection speed from bridge to router shows at 1170Mbps. I haven't done any throughput tests yet.
I also have an A6200 adapter so will see if update makes any difference with that.
I've think tried all the versions of firmware and this new one seems good so far, so we'll see.
Move your dynamic range so that fixed assignments are no longer in the dynamic range.
That should help with collisions.
According the RFC, a device owns it's lease until expiration, but should check in for a renewal when half it's lease expires (at which time the DHCP server can relocate the IP).
Microsoft OSes have been known to wait out the lease, expire it, and request a renewal afterwards thus losing all active connections.
The new firmware update didn't fix the streaming problem for the Xbox 360. I have confirmed it on my original R6300 & the replacement R6300 that I picked up at BestBuy tonight.
I found out an interesting bit of information at Bestbuy though. Apparently there is a policy between them & Netgear concerning these routers. I was told that they were authorized to just return them if the customer wishes. Even if the original 30 days from purchase has expired. This type of policy is what will keep me interested in future Netgear product.Smiley Happy
This new one is going back too.Smiley Very Happy
I'm just going to stick with my 3700 until this router matures.
Apprentice
right, that's part of the problem ... upgrading the router involves resetting to factory defaults. Doing that while the router is still connected to your network resets the DHCP range to 2-255. So now your devices are picking up all kinds of IP addresses within the reset range. A way around this is to remove the router from the network and upgrade it from a standalone PC first.
Luminary
it's no 2-255
correct range is 2-254
255 is broadcasting and doesn't include in DHCP scope of pool range
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Apprentice
jmizoguchi wrote:
it's no 2-255
yup ... 254, what was I thinking???
Tutor
Just keepin ya honest......lol
I upgraded yesterday without a reset to factory defaults. Did a power restart and all is fine with my setup.
Tutor
What do mean by fine?
can you give us details?
Discussion Stats
  • 34 replies
  • 9623 views
  • 0 kudos
  • 11 in conversation
Top Contributors
