Reply
Port 520
GRC's Shields Up test shows that TCP Port 520 (Extended File Name Server) is closed but not hidden. Is there a setting w/i the R6300 to hide this port from port scanning applications?
I only have one router so I have no idea why I'm seeing this.
"The descent to hell is easy. The gates stand open day and night. But to reclimb the slope to the upper air: this is labor" -- Virgil, Aeneid, Book 6
________________________________
NETGEAR products:
(1) NETGEAR R6300v1
(1) NETGEAR R6300v2
Retired_Member
Re: Port 520
No setting. Turn off UPNP if on and check for apps running on your devices.
Look under UPNP it might show the device IP using that port.
Are you using MAC by chance?
Luminary
Re: Port 520
Here is similar incident
http://forum1.netgear.com/showthread.php?t=81550
May want to check your devices behind that may using it
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Re: Port 520
I have an iMac, if that's what you mean. I'm running two VMs (Windows XP Pro and Windows 7 Pro) through Parallels 9 and wonder if that may have something to do with it.
NETGEAR products:
(1) NETGEAR R6300v1
(1) NETGEAR R6300v2
Luminary
Re: Port 520
Unlikely the O/S is the issues but any application can request with uPnP is enabled.
Using wireshark will quicker to see if any application is requesting it
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: Port 520
I'm currently using Wireshark to see what I can find. Nothing found yet after 15 minutes of captures.
NETGEAR products:
(1) NETGEAR R6300v1
(1) NETGEAR R6300v2
Retired_Member
Re: Port 520
When I searched this problem I found a article that suggested that MAC's had been found to use this port as your OP suggested.
Easy enough to find out turn mac off run test again.
Re: Port 520
RIP uses that port. Check your router to see if RIP Version, under Advanced->Setup->LAN Setup, has changed from Disabled. I found this out accidentally, when I flashed to an earlier firmware version and played around with the settings.
I just tried it before posting this and when you set it to RIP Vers 1 or Vers 2, it will show up in GRC.com. A reboot is necessary after disabling it!
Discussion Stats
  • 7 replies
  • 4274 views
  • 0 kudos
  • 4 in conversation
Top Contributors
