Reply
R6300 Big Bandwith Problem
I purchased an R6300 for my home. I have 100 Mbps service from Charter. I have ethernet cable from the Cisco modem to the router and the same from the router to my main PC and a TIVO. My problem is that I'm getting HALF the performance I should be getting. With the router inline, speed tests give me 45-50 Mbps. When I take the router out and go direct from the modem to the PC, I get 90-95 Mbps. Remember that this is all hardline (Cat 5E) that works great directly from the router.
I addressed this with Netgear support and gave up after three days when the tech told me he "had to check his resources and his supervisor and would call me back in ten minutes". That was this morning. After no retrun call, I brought the router back to Best Buy and they asked that I swap it and see if the problem still existed. I did and it still does. I'm ready to bring it back tommorow because I'm totally frustrated with this.
Can anyone help me out with this. I love the router and don't want to bring it back. But there's only so many hours in a day that I can continue to mess with this.
Thanks!
Re: R6300 Big Bandwith Problem
How do you test the performance, some web service like speedtest.net?
Were you testing it on one Ethernet client only (no other clients attached)?
Do you have any special Router settings other than default?
Yes, I do use Speedtest.net, the same one that Charter uses. And it uses Charter's server.
I tested it several ways. With just the one machine, then in different configurations that included (or not) another Ethernet machine attached through a gigabit switch; A TIVO DVR on Ethernet cable; and several wireless clients - another PC using a Range Max WiFi adapter and 3 or 4 iPhone/iPad/WiFi printer clients. My testing though, has been with just the one PC with the Ethernet cable.
I have the current firmware and the only change that was ever made to the settings was the MTU - from 1500 to 1400, at the phone tech's request. That did nothing and I'm on the second router now with no change.
And FWIW, I just ran speedtest.net on the machine with the Range Max Wireless Adapter and it's running 57-60 Mbps; Faster than the hardwired machine... :confused:
Well I know that this won't get "approved" but the forum help looks as good as the help I got from Netgear support - non existent. I have what is supposed to be the flagship of the Netgear home line and I am about to bring the second one back to the store where I bought it. Buyer beware...
I have similar results w/ or w/o R6300 on speedtest.net.
According to smallnetbuilder the router has around 800 Mbps WAN <-> LAN routing performance, and with it's gigabit ethernet ports, it should not be a problem for the router to handle the provisioned speeds from most ISPs.
http://www.smallnetbuilder.com/wireless/wireless-reviews/31799-netgear-r6300-wifi-router-80211ac-dua...
Wonder if it is Ethernet PHY IOT related... What's your PC's Ethernet adapter? Try to fix it to 1.0 Gbps/full duplex or 100 Mbps/full duplex.
i started a thread just before this regarding performance on my same router. i have 105mbps connex from comcast, tested across 5 separate devices independently with 1.0gps ethernet connex, and i am only receiving 50% of my signal. i too am about to return this $200 router, extremely frustrating how difficult it is to get any type of help from Netgear support. This forum has awesome members, but so far the only suggestion of disabling WMM has not bared any fruit.Smiley Sad
Well, I brought the first one back to B*** B** and exchanged it for another router. I believe it is a problem inherent to these R6300 units. I pulled it off the line and replaced it with a "Gamers Lounge" and got 90-95 Mbps. After exchanging it for another of a different make, again - I got 90-95. All of my gear is gigabit where it can be and I'm using Cat 5e Ethernet cables. Again, the only link in the chain that could have caused this problem is the R6300. Thats' two units off the shelf at B*** B** and taken out of a potential sale. Sooner or later, someone with Netgear might figure out that they should look at these. The flagship of the line hit an iceberg in my book... Thanks to the members that tried to help. I really do appreciate it. I'm angry about companies that don't consider that you come to them to buy a product expecting it to function. When it flops and you return it, YOU have to spend time and gasoline to revisit them for the return. And if you work with them and try another unit just the same and IT flops, I'd expect nothing short of patience and and a smile. Unfortunately, I got neither. Smiley Sad
Jester, do you see it takes longer for your Ethernet client adapter to negotiate with the R6300 than the other two routers? i.e. when plugging into the Ethernet cable, it takes more time for the 'network icon' at the system tray to display connected (and get the ip).
Is your PC's Ethernet adapter an Intel one? Or what model/make?
Apprentice
I'm not sure I understand what is meant by the phrase: "i am only receiving 50% of my signal"
What signal are you referring to and how are you measuring it?
4xR6300 AC1750 V1 - V1.0.2.78_1.0.58 whole house router+wireless. 51 devices connected.
1xWNDR3700 N600 V2 - V1.0.1.14 provides internet to my first floor and back yard
2xWNDR3400 N600 V1 - V1.0.0.50_20.0.59 running faithfully in a crowded apt building
2xWNDR3300 N600 V1 - V1.0.45 over 2 years since reboot
3xWRT54G/GS - DD-WRT what can you say about the legendary WRT54
DIR-615 vC1 3.13NA - great little router
DIR-655 vA3 1.37NA - RETIRED never worked right with OOMA
EDIMAX EW-7416APn v2 1.13
all NETGEARS are factory recertified except 1xWNDR3400
HOW TO: My router firmware upgrade instructions:
http://forum1.netgear.com/showpost.php?p=425691&postcount=4
HOW TO: Reinstall the firmware on a router without the setup CD recovery tool
http://kb.netgear.com/app/answers/detail/a_id/19841/~/reinstall-the-firmware-on-a-router-without-the-setup-cd-recovery-tool
HOW TO: Extend AP on separate LAN
http://forum1.netgear.com/showpost.php?p=479421&postcount=5
HOW TO: Extend AP on the same LAN
http://forum1.netgear.com/showpost.php?p=481991&postcount=2
A final tip of the hat... Here is this morning's speedtest off of the Charter servers closest to me using my new C***o E4500 router. This is all that I wanted from the Netgear R6300 router. Or, tech support from Netgear - OR tech support/courtesy from Best Buy. Now I own the competitions router and it kicks a**. I gave both companies from July 3 to yesterday (July 19th) to help me get this straight. I can thank the moderators here for posting my stuff. I never thought they'd do it. Hopefully, someone will benefit. Thanks! :cool:
I have Charter's 100mbps and just did a run thru Speedtest.net. I ran it from my laptop, which was connected wired from my R6300 and then thru THREE(3) Netgear gigabit switches to my laptop.
My speeds... 95.44mbps down, 5.25mbps up with a 15ms ping
Nothing at all wrong with the throughput.
FYI, just to be consistent with you, I ran the same Charter test, just to check...
Given the Chuck_IV's results, R6300 seems to work OK under the same ISP and service plan via Ethernet.
And according to Jester's observation, that under speedtest.net ethernet's test speed is actually worse than wireless's (57-60 Mbps). I'm wondering there is something related to the IOT between R6300's ethernet switch and Jester's ethernet adapter.
Jester, why not sharing your adapter information so probably there are others who have the same may advise?
I wasn't using wireless. I was using a hard line Ethernet Cat 5e cable going through one Cisco 5 port gigabit switch. Wireless access is important to me, but it's speed is not the highest priority. I need the speed for the hardline. I'm sorry things didn't work out. Netgear sent me some inquiries on it, but to be honest, Best Buy ruined any chance of me doing anything other than what I've already done... Buy another router, then stay as far away from Best Buy as possible. Bad, bad taste. I see why they're going down and laying people off. Several of the associates at the store I went to were totally unacceptable. Want to lay off people? Appoint secret shoppers with product returns who show a little impatience. When the clerk rolls his eyes sarcastically at the shopper, "lay them off". At least you keep the ones who care...
I have to say that I really wish I would have tried to set up everything before I downloadded the latest FW update because the 2.4ghz 11n speed is garbage with the 2.14 FW installed. I am running at 5.5Mbps -13 Mbps and was running 243 -300Mbps on the old router WNR3500L. Just wondering if I should downgrade the FW before I return this router.....
Novice
Yes definitely try that. Firmware 2.14 has problems and I'm not sure why they released it.
Discussion Stats
  • 16 replies
  • 17661 views
  • 0 kudos
  • 7 in conversation
Top Contributors
