Reply
Follower
R6300 Corrupt Firmware File
I have a slow blinking green power symbol and a solid orange internet symbol. Apparently this is due to a corrupt firmware.
I found a walk through fix on a Netgear support page which has me using the command prompt to reinstall the firmware. This has not worked. Not sure if I'm doing something wrong.
Here is a quick little copy and past of what Netgear support is telling me to do. This reads a bit weird to me so if anyone can help would be great...
"Run the command tftp -i 192.168.1.1 put firmware_filename, where firmware_filename is the actual name of the firmware file"
Cheers.
Luminary
Re: R6300 Corrupt Firmware File
You may still have corrupted router . I would consider contact support
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 3379 views
  • 0 kudos
  • 2 in conversation
Top Contributors
