Reply
Xbox 360 Dropping Connection
My 6300 drops the wireless connection to my xbox 360. The xbox shows 5 full bars but is very slow. I use it as an extender. When I run the network tuning wizard in Windows Media Center Extender on the xbox it shows 1 bar sometimes, sometimes it drops the connection. If I switch back to the xbox dashboard & check the signal strength it still shows 5 full bars. Signing into xbox live is painfully slow. The xbox gets disconnected if I try to stream anything from my HTPC. The HTPC is wired. With the xbox wired everything works as it should.
I setup my WNDR3700v2 as an access point. I connected to the 2.4 Ghz on the 3700 without any problems. Xbox shows 5 bars in extender mode & on the dashboard. Network speed in this configuration behaves just like a wired connection. Very fast. This test eliminated the xbox as the problem.
My laptop & my small kitchen HTPC connect at between 300 & 450 Mbps on both the 2.4 & 5 Ghz bands. Network transfer speeds are right where they should be.
There are no other wireless networks in my area. I did not have any other wireless devices turned on when trying to get the xbox to connect to the 6300.
These tests confirmed that the problem lies with the 6300. Using firmware version 1.0.2.26_1.0.26
Anybody else have this problem?
Apprentice
Re: Xbox 360 Dropping Connection
My 6300 drops the wireless connection to my xbox 360. The xbox shows 5 full bars but is very slow. I use it as an extender. What are you using as an extender? the XBox or the R6300? It almost sounds like either the XBox or the Media Center is connecting to another wireless network, like a neighbor, perhaps? When you connect to the 3700, you are connecting to your LAN. How do you have the 3700 configured? where does it get its network connection from?
4xR6300 AC1750 V1 - V1.0.2.78_1.0.58 whole house router+wireless. 51 devices connected.
1xWNDR3700 N600 V2 - V1.0.1.14 provides internet to my first floor and back yard
2xWNDR3400 N600 V1 - V1.0.0.50_20.0.59 running faithfully in a crowded apt building
2xWNDR3300 N600 V1 - V1.0.45 over 2 years since reboot
3xWRT54G/GS - DD-WRT what can you say about the legendary WRT54
DIR-615 vC1 3.13NA - great little router
DIR-655 vA3 1.37NA - RETIRED never worked right with OOMA
EDIMAX EW-7416APn v2 1.13
all NETGEARS are factory recertified except 1xWNDR3400
HOW TO: My router firmware upgrade instructions:
http://forum1.netgear.com/showpost.php?p=425691&postcount=4
HOW TO: Reinstall the firmware on a router without the setup CD recovery tool
http://kb.netgear.com/app/answers/detail/a_id/19841/~/reinstall-the-firmware-on-a-router-without-the-setup-cd-recovery-tool
HOW TO: Extend AP on separate LAN
http://forum1.netgear.com/showpost.php?p=479421&postcount=5
HOW TO: Extend AP on the same LAN
http://forum1.netgear.com/showpost.php?p=481991&postcount=2
Luminary
Tikiman2012 wrote:
Are you trying to be a smartass?
Read the post.
If you are coming to get forum to get help. BE HUMBLE and reply with neutral.
You posted in offended way. Think twice before you post
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Virtuoso
Tikiman2012, your last post has been removed, do not respond in such a disrespectful way again to someone who is trying to help you.
I'm having the same issues. I'm using the Xbox 360 as a media extender and getting horrible performance. Laptops are fine but interface in mediacenter lags really bad. Used the tune network option (within mediacenter) and bandwidth is very low. The Xbox is showing great signal strength. And I checked with my laptop from that location and I'm getting better signal strength than with my Linksys AP. When using the Linksys AP, the bandwidth graph is at the top of the scale where the R6300 is near the bottom. I'm running the latest firmware (R6300-V1.0.2.36_1.0.28). I was hoping for better range (which is seems like it has), but not working with my xbox as an extender is a deal breaker.
It wasn't disrespectful. It was a direct & honest question. He asked questions that were directly answered in my original post. I wasn't trying to offend anyone. Sorry if I came across that way. I am a very direct person.
I had read somewhere that not using channel 1 on the 2.4Ghz band helps. I have tried different channels & it hasn't helped me. I switched back to firmware V1.0.2.10_1.0.21. Going to give V1.0.2.36_1.0.28 a try & see if it helps me. I'll let ya know what I find.
I tried different channels too. And changed about every setting I could think of. I'm wondering if the xbox is connecting at b/g instead of n. Family is using network right now so can't mess with it (I put the Linksys back in).
My Xbox 360 drops connection to Xbox Live while it is HARD WIRED to the R6300. I've opened all ports that Xbox suggests, given the Xbox a static IP and reserved it on the R6300 but It will only stay connected for a short period (10-20 minutes) and will disconnect while in play or streaming. The connection is stable while connected to my modem. (but then there's no access to my NAS) Any suggestions?
Still have the problem with the xbox with the new firmware. It's fine when it's wired. Going back to using my WNDR3700v2. At least that router is reliable.
The new firmware update didn't fix the streaming problem for the Xbox 360. I have confirmed it on my original R6300 & the replacement R6300 that I picked up at BestBuy tonight.
I found out an interesting bit of information at Bestbuy though. Apparently there is a policy between them & Netgear concerning these routers. I was told that they were authorized to just return them if the customer wishes. Even if the original 30 days from purchase has expired. This type of policy is what will keep me interested in future Netgear product.Smiley Happy
This new one is going back too.Smiley Very Happy
I'm just going to stick with my 3700 until this router matures.
My WMC/Xbox 360 streaming with the R6300 is fine. Both my Win7 WMC laptop and the Xbox 360 connects to the R6300 on 2.4GHz. I could stream HD movies without latency.
My FW is 1.0.2.26, with router default settings. Haven't tried the latest 1.0.2.36 yet.
Could it be the model difference of Xbox 360? Which model do you guys use?
mine is the new 360. My older ones are hardwired and don't have an issue.
My 360 is the new slim one. When it's hardwired it works fine. When it's on wireless with the 6300 it doesn't work. When it's on wireless with my 3700 router, it works fine.
Novice
XBox 360 Live (build-in 2.4 networking) connected fine on my WNDR 4500. However, the connection did not work at all with the R6300 I just bought.
I posted what I did to fix this (pending moderation, I think) but I set a static IP for the XBox 360, opendc NAT Filtering, set default DMZ server for your static IP, set port triggering for any user for ports 88 and 3074, and set port forwarding for ports 80, 88, and (if you can, i failed) 3074 for the static IP.
Turn off the router for 2 minutes. Turn on. Pray.
(P.S. If you could tell me what the conflict was that prevented me setting up port forwarding for 3074, I would appreciate it.)
Anyway, all of that worked, XBox 360 Live now works. But, my WNDR 4500 just worked out of the box. Sigh. Netgear, comments or suggestions on my efforts would be appreciated.
Discussion Stats
  • 14 replies
  • 7036 views
  • 0 kudos
  • 8 in conversation
Top Contributors
