- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Could not connect to Readycloud
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have a readynas 516. Current version is 6.9.3. I have Readycloud in switched off mode. If I try to switch on by sliding, it asks my email and login password, once I give, it says "There is something preventing ReadyNAS from connecting to Readycloud Server. Please reboot your ReadyNAS and try again." I have a internet connection in my readynas 516 with DNS 1.1.1.1 and 1.0.0.1. From network it is reachable. I have downloaded Readycloud and installed on a desktop. When I login, it says, currently you have no registered devices. Serial number of the device is 3C82360C01375. I could login to the device through admin password and could login with RAIDar also. Please guide me how to solve this.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great! I had to remove a very old config file so the system could generate it again when you enabled ReadyCLOUD.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Could not connect to Readycloud
When you look at the cloud page on the NAS, are you seeing the two green checks (one for internet available, the second for services available)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
On cloud page of ReadyNAS, I am not finding any green check. Please see the snapshot attached herewith.
janakiraman
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please send in your logs (see the Sending Logs link in my sig).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Please check your email for the system logs.
janakiraman
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please go to System > Settings > Support and PM me the 5-digit number that you then get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to turn the ReadyCloud service on before you'll see the green checks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The code you sent didn't work. Please disable Secure Diagnostic mode and re-enable it and let me know the 5-digit number that you then get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I did the same as you told. Again it has generated 52328 only.
With regards,
janakiraman
- Mark as New
- Bookmark
- Subscribe
- Permalink
please see the attachment.
janakiraman
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is your NAS able to connect to the internet?
If you configured a static IP address on the NAS, make sure you added a DNS server - that is often overlooked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please shutdown your NAS, disconnect the power for a few minutes, power on the NAS again, turn Secure Diagnostic Mode back on and let me know the 5-digit number that you then get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As you said, I have shut the NAS down, removed the power cables and restarted after 5 minutes. Then, in settings > Support> Secure Diagnostic mode selected. Still it is showing the same port number only. Port no.52328.
I can give you access if you want through my static ip. static ip is 203.153.36.226.
With regards,
janakiraman
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reboot it normally this time and check if ReadyCLOUD works then.
Port forwarding is not needed. In any case that port isn't the port number on your NAS.
Although unrelated to your problem I took the opportunity of remote access to your system to get the BIOS on your system updated to the latest.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I did the same as you told, rebooted it normally and tried to connect but gave an error. Then clicked ReadyNAS in CLOUD menu. I have pressed the touch screen up arrow and found "Discovery on" and pressed OK button. Retried to connect but Still it is giving the same error. Please see the snapshots for clarity.
janakiraman
- Mark as New
- Bookmark
- Subscribe
- Permalink
What about trying to configure ReadyCLOUD from the Cloud tab of the web admin page?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I could not do from webpage also. Please see the snapshot.
janakiraman
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have sent the fresh logs through mail. Please check.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I have not tried that version
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please re-enable Secure Diagnostic Mode and let me know the 5-digit number that you then get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same port number only. No change. I have rebooted and again enabled also. The number is not changing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please try enabling ReadyCLOUD again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Success.!!!!! ha ha ha. Now it is enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
