- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN102 no longer working with ReadyCloud.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware is 6.6.1 and the problem is that I can't access the NAS through the cloud. It once work fine and for about a year no problem. I have set it back up the way it did work before and still nothing. I have rebooted the NAS still nothing, please help because this is the main reason I bought this units was to access it remotely.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have it working now.....don't know what I did but I did follow everything in this last posting and it's working now.
Thank you
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN102 no longer working with ReadyCloud.
Are you affected by this? https://kb.netgear.com/000038517/Why-can-t-I-access-my-ReadyNAS-system-using-ReadyCLOUD
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have not lost any files and I can access the Server locally. I can't access it at all using the ReadyCloud app from any devices that I've once could.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And I follow the steps stated here and have the screenshots of how it's setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't see your screenshots because they weren't approved yet by a moderator.
The ReadyCLOUD issue is not just about data loss. You also need to reactivate it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I here are two of the pictures and I'm sure that I have reconnected it. Maybe I missed something.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Once a moderator have approved your pictures, I hope to be able to help you further.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Jorayh73,
What do you see when you click Home? This should show the shares of your NAS. Manage tab is where you will see the ReadyCloud users you have added.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In the Shares tab I see the folder that I want and it shows my admin and cloud account to the left of it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Jorayh73,
From what I understand is you are not able to access your NAS via ReadyCloud portal. Looking at the screenshots you sent, I saw on the first image that your NAS is detected on the ReadyCloud portal, so I asked what you see under Home tab as this should show you the shares of the NAS, and when you click Manage tab, you should see the ReadyCloud users you have invited. Is this what you see? Because if yes then you are able to access the NAS via ReadyCloud. If you want to get to the admin page remotely, you should be using ReadyCloud desktop app, but if you are just locally getting to the admin page, it is much better to use http://<LAN IP of the NAS>/admin (ex: http://192.168.5.1/admin).
Correct me if I'm wrong please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok please see images.....because I believe I have everything that you stated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
First make sure that any data in the home folders for your ReadyCLOUD users is backed up. Then go to the Cloud tab on the local web admin page, leave ReadyCLOUD and try joining it again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have the same prob
i have a RN102-100
with 2 (2Tb Drives)
wife could not get on readycloud and looking in to it
on front view the cloud owner account was removed and readycloud was turned off
i resighned in and loged in even with admin login and ALL the privat home Shares where not there
this nas is my 2nd and dident have much on it atleast in space but where did it all go
how do i get it all back
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you had data loss craer there are instructions on how to contact support in the article jak0lantash linked to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
With a little bit more punctuation, this would have been easier to read.
You should now wait for NETGEAR Support to get in touch with you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
craer please make sure you either connect a USB disk to your ReadyNAS or provide support with details to backup to some other network storage on your network. We can't start the data recovery attempt without this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
And just by the way I appreciate the help I've never been on a form that I have had this much attention so quickly with help rather than BS
- Mark as New
- Bookmark
- Subscribe
- Permalink
update
no clue whats going on . i think thay closed the case helping me i have no clue whats being done this is what i got after thay asked for the emails of the accounts that where on readycloud with lost data and then it tells me the case was closed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. Connect a USB disk and update the new case to indicate that you've done that.
You have two MyNETGEAR accounts and the unit is registered to a different profile to the one you emailed from so they opened a case for the profile your unit is registered against and closed the other one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
got ya ya i dont see a new case in my account i did get a 1Tb usb3.0 drive on there a little bit a go when i got home... i dident know what email thay wanted.. the way i have mine set up is i have a email just that owens the readycloud account "cloud owner" then ones for all the account mine my fifes my friends to use it.. so we all have a privite share folder for are own stuff and then the public ones. i am new to this ready cloud stuff i liked the way the onld remote system worked. it all fell under local accouns and had remote access to the files wile still haveing are own folders for are own stuff that was privite from other accounts on the same cloud
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your NAS isn't registered it automatically registers to your ReadyCLOUD admin account when joining it to ReadyCLOUD.
