Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN104 Router Ports to open
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-13
01:32 PM
2015-03-13
01:32 PM
Hi, to make sure everything works well (things like readycloud) what ports do i need to open on my router? ive got port 80 and 21 pointing to the readynas, do i need anything else for readycloud? (read something about leaf vpn and want to make sure im using everything).
thanks
thanks
Message 1 of 10
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-13
02:38 PM
2015-03-13
02:38 PM
Re: RN104 Router Ports to open
If you can access readycloud fine then there is no need to open a port for it. If you are asking what port it uses, the default is 6300 which you can also modify. Go to cloud>remote>settings
Message 2 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-13
02:59 PM
2015-03-13
02:59 PM
FWIW, personally I'd limit external access to https (meaning I wouldn't open port 80). Port 21 is for FTP - it is only needed if you access the NAS with an FTP client.
Message 3 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-14
09:16 AM
2015-03-14
09:16 AM
OK thanks. I've closed 80 and opened 443. The security warning is annoying but better to be secure.
I've not opened 6300 but as nhellie says it seems to work fine. Thanks for the help
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-14
09:30 AM
2015-03-14
09:30 AM
If you use FTP, you will also need to specify a smaller range of passive ports in the NAS, and then forward them in the router.
4 passive ports are enough for me. The port numbers you pick should be in the range 49152-65535.
FWIW, with firefox you can easily add an exception to eliminate the warning. I use both firefox and chrome, and with chrome I just click through it.
Message 5 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-14
01:15 PM
2015-03-14
01:15 PM
Why do you want to leave port 443 permanently open?
Message 6 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-14
01:26 PM
2015-03-14
01:26 PM
On my router so I can connect to the administration page externally
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-14
04:03 PM
2015-03-14
04:03 PM
You can also browse shares if you have http access enabled for them.
hawke84 wrote: On my router so I can connect to the administration page externally
If you wish you can also use the secondary https feature. For instance, assign 54321 as the secondary port, and forward that. Then access via https://ddnsname:54321/admin This is useful if you have other devices that can be managed remotely (perhaps the router itself).
It's important to choose good passwords if you forward ports.
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-04-16
08:29 PM
2015-04-16
08:29 PM
I decided to give readycloud a try again, but I don't see any shares via readycloud. I've opened port 6300 but that doesn't help. When I click on "admin" next to my nas, it says "I must be on the same lan to use the admin feature" but I am on the same lan. Discover doesn't find my nas either but if I put in my serial number it will give me the manage button. Honestly I can't find anything in readycloud that works :-(. Maybe I've closed some relevant port or something. I'm on a mac client running chrome if that matters. Is there a better way? What happened to webdav?
steve
steve
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-04-17
03:21 AM
2015-04-17
03:21 AM
Personally I use ftps and https remotely.
webdav is supported in the RN104.
Message 10 of 10
