Orbi WiFi 7 RBE973
Reply
ReadyCLOUD Invitations are not delivered
mike_coreit
Hi I have an issue where a user is unable to activate their ReadyCLOUD account due to the web page giving the message 'The invitation is no longer valid'. I have removed and re-invited the user but they don't receive any new invitation email. Is there any way to resolve that?
Model: RN10200|ReadyNAS 100 Series 2- Bay (Diskless)
Message 1 of 9
Accepted Solutions
mike_coreit
Re: ReadyCLOUD Invitations are not delivered
Hi I have spoken with Netgear support but they said the issue was chargeable because there was a setting on the device which needed to be adjusted. I was able to work-around the issue by creating a new email alias on the user's email server, then set-up the account using this.
Message 9 of 9
All Replies
Retired_Member
Not applicable
Hi mike_coreit
when you sent invitation in ReadyCLOUD web portal then you will receive the email in your own email box,you can forward it to your friend instead.
Message 2 of 9
mike_coreit
Hi I also didn't receive any notification to my own email
Message 3 of 9
FramerV
NETGEAR Employee Retired
Hi mike_coreit,
I am assuming that you have already finished the steps described on the link below:
How do I add my ReadyNAS OS 6 storage system to my ReadyCLOUD Account?
If you have, kindly try to create the account first on readycloud.netgear.com then follow the steps below:
How do I use ReadyCLOUD to allow or remove share access for remote users?
Message 4 of 9
mike_coreit
Yes I have already followed the steps of enabling ReadyCLOUD and adding the user via the readycloud.netgear.com portal
Message 5 of 9
FramerV
Hi mike_coreit,
Could you try the following steps:
Creating a secondary Readycloud users:
Step 1, Create an account for ReadyCloud secondary user.
https://readycloud.netgear.com/client/index.html#page=access
Example ReadyCloud ID: sample@gmail.com
Step 2, Create an account for Remote with the same email address.
http://remote.readynas.com/index.jsp?pid=4
Example Remote ID: sample123
Step 3, Click Upgrade Your Existing ReadyCloud Account
Step 4. Enter the Remote ID and Password. Click Start the Upgrade process
Readycloud username: nettie.m.garcia
Readycloud password:
Step 5: Once the Remote and Readycloud accounts successful binded, we can ask the admin cloud user to send share invitation.
Step 6: Check your email regarding readycloud invitation and click the Link.
Step7: It will route to ReadyCloud Web portal asking you to login using the Cloud ID.
NOTE:  The accounts are just examples. Please use your own account for it.
Message 6 of 9
mike_coreit
Hi I have created a login via the Create Account option (readycloud.netgear.com), and I have created an account on remote.readynas.com. I logged in to the ReadyCLOUD account and chose to bind the account, next I re-added the invite but still we don't receive any email for this. When I log in to ReadyCLOUD with the new account it gives the message 'Currently you have no registered or shared devices'
Message 7 of 9
FramerV
Hi mike_coreit,
Might be best if you get in touch with support now.
Contact NETGEAR Support
Or you can also wait for other forum posters to pitch in.
Message 8 of 9
mike_coreit
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3793 views
  • 0 kudos
  • 3 in conversation
Announcements
