Orbi WiFi 7 RBE973
Reply
ReadyCloud Folder Not Available
aniraghome
Tutor
Ref: https://community.netgear.com/t5/ReadyCLOUD/Ready-Cloud-Folder-Not-Available/m-p/1553051#M10268
no luck with that for me i left and rejoined still keep getting the same error "network error" on my iphone readycould app
Model: ReadyNAS-3100|ReadyNAS-3100
Message 1 of 10
Accepted Solutions
JohnCM_S
NETGEAR Employee Retired
Re: Ready Cloud Folder Not Available
Hi aniraghome,
There is a new version of Readycloud app for iOS (2.0.2). You may try installing that and see if that will resolve the issue.
Message 9 of 10
All Replies
Marc_V
Hi @aniraghome
What FW is installed on your NAS? Have you tried installing v2.0.1?
Please make sure that you are connected to the LAN or thru mobile data when trying to connect and also your NAS should have the Internet and Services check marks available.
You can also check the Network settings of your NAS and Add DNS 8.8.8.8 and your Router address.
Hope this helps!
Regards
Message 2 of 10
aniraghome
Tutor
Yes i have installed 2.0.1 app on my iphone connected to LAN . Both internet and services are green checked always. Cloud does show my nas its just not connecting. It gives a message network error.
Message 3 of 10
Marc_V
Can you provide us a Screenshot of the error? Can you login and access your NAS when using the portal?
Message 4 of 10
aniraghome
Tutor
The error message is a small pop up message “network error occurred “
Yes i can login to readynas cloud portal on computer it even discovers the nas.
Message 5 of 10
Marc_V
Hi @aniraghome
Can you try connecting to ReadyCloud App using mobile data instead of LAN? Have you tried using a different device when connecting?
Regards
Message 6 of 10
aniraghome
Tutor
Hi Marc_V
Yes i am able to upload via cellular data i get the error with my home wifi.
I also tried with a different iphone and ipad same issue cellular data works wifi doesnt
Message 7 of 10
Marc_V
Hi @aniraghome
You might want to try the 6.9.4 BETA which has fix for ReadyCloud issues. ReadyNAS OS 6.9.4
Regards
Message 8 of 10
JohnCM_S
Hi aniraghome,
Message 9 of 10
aniraghome
Tutor
Yes just downloaded the new version of cloud app fixed all issues . Things are back to normal from nally.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 4215 views
  • 0 kudos
  • 3 in conversation
Announcements
