- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Removing invited cloud users
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I would like to remove a cloud user account from Netgear ReadyNAS 31400, who are not longer working at our organisation. However, I receive the message saying I need to sign into the ReadyCloud to remove the user. After signing into the ReadyCloud, I still cannot remove the account.
The account was initially set up by someone the person has left the organisation and did not set up completely. Please could you advise? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Removing invited cloud users
Hi @Jake2
Have you logged in the admin or main account? Please see Removing ReadyCloud users. Or possible the account you are trying to remove is where the NAS is joined to.
You may want to try deactivating ReadyCloud on the RN314. then Re-enable it. If you are not updated to 6.9.4 you may also want to do that first.
Hope this helps!
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have signed into the local admin account and tried to remove the Cloud user account. I've been pointed to remove ReadyCloud to remove the cloud user. I do not have the cloud admin account in ReadyCloud, but I have accessed to the user account in ReadyCloud and tried to remove the account without my luck.
You may want to try deactivating ReadyCloud on the RN314. then Re-enable it. If you are not updated to 6.9.4 you may also want to do that first. > No, I have not upgraded to 6.9.4.
Hope this helps!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
You have to login to readycloud.netgear.com using the Cloud admin account > Apparently, we only have this user account in ReadyCloud.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Jake2
I see, so you only have this user account? In that case, login to the Local Administration page then go to Cloud tab and click leave on the ReadyCloud Service.
This will remove the user account, remove the NAS from ReadyCloud and turn off the service. Note that this will remove the Home folders and Data inside it.
Hope this helps!
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Login to the Local Administration page then go to Cloud tab and click leave on the ReadyCloud Service - I would like to do this, but there is no options as shown in the image.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Your NAS is already removed from ReadyCloud. The user account does not have any association with your NAS anymore. > Yes, you are right. However, I can still see this user account links to our NAS as shown in the image.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Jake2
Have you tried OS-Reinstall? This will also set some settings to default like the password for your Administration page will be on default and your Network settings.
Also, you may want to rejoin the NAS using the main account and see if it will remove the user.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Have you tried OS-Reinstall? > I don't think it is a good option for me. It will be a disaster for me as we have all staff depend on the NAS. Do you have any option?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
You may want to try joining the NAS to ReadyCloud once more using the previous main account or contact Support so they can get a case escalated, experts will request for backend access and remove or repair configuration.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Joining the NAS to ReadyCloud once more using the previous main account > Does this mean I need to turn on the ReadyCloud? Could you guide me how to remove the account? In addition, when I turn on the ReadyCloud, wlll this sync all my folders to Cloud?
Contact Support > Please could I have contacted information?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
.Hi @Jake2,
You can create a case number for Support by logging in to https://my.netgear.com Make sure your NAS is registered.
Joining the NAS to ReadyCloud does not sync all your folders on the Cloud, you still need to set the permissions on what shares will be allowed to be accessed. Here is an article on removing ReadyCloud users.
Again, you have to use the account that was used to invite the said user.
Hope this helps!
Regards
