Orbi WiFi 7 RBE973
Reply
Removing invited cloud users
HansK
Apprentice
I have invited some users to connect as a cloud user on my readynas 104. They all show up in the list cloud users. One of them however, has stil not aknowledged his use and in the list with cloud users, it still shows up withe the email icon. I can delete all other users by clicking on them and select Disable. I would like to remove this invited person but I can not delete him. How can I remove this invite from the list?
Message 1 of 6
Accepted Solutions
OOM-9
NETGEAR Expert
Re: Removing invited cloud users
Those images were small, but I think I was able to make them out.
I will send you a PM with some quesitons.
Edit: This is something that should not happen. There is a communication issue that may have happened and was corrected.
Message 6 of 6
All Replies
OOM-9
NETGEAR Expert
Disabling is not quite like deleting. This would be why they are still showing up.
Since they are cloud users, you will need to log into https://readycloud.netgear.com ; there you will go to the manage tab.
You will have a list of users on this page, and you can delete the users which will remove them from your ReadyNAS device.
Message 2 of 6
HansK
Apprentice
Thanks for your answer but the user That has not yet accepted the initation does not show in this list. Therefore I can't delete this entry here.
Message 3 of 6
OOM-9
NETGEAR Expert
The invited users that did not accept the invitation would not show up in the ReadyNAS user list.
You would need to manage the invitations on ReadyCLOUD. Did you check the list of users/invitations there?
Message 4 of 6
HansK
Apprentice
The invited user does show up in the readynas cloud user list but not in de readycloud user list.
REAdynas screen shotRcloud user list screenshot
Message 5 of 6
OOM-9
NETGEAR Expert
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 5682 views
  • 1 kudo
  • 2 in conversation
Announcements
