Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AFP drops connection with [T15]
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-16
11:02 AM
2012-06-16
11:02 AM
Really hoping someone can help. This has been happening consistently for the last couple of months, starting with OSX 10.7.3 and 4.1.8. I'm now on 4.1.9 [T15], same issue.
I tried renaming the /etc/netatalk folder, re-installing the Raidiator software [T15]. It did re-create the folder with default settings, and I can start AFP, but as soon as I connect using OSX 10.7.4, the connection disappears, so the problem is still there. Any ideas? What can I do, short of starting from scratch?
Here's the process entry list showing AFP is running:
root 4035 0.0 0.5 2400 1184 ? Ss 10:11 0:00 /frontview/bin/monitor_enclosure
root 4180 0.0 0.3 2016 896 ttyS1 Ss+ 10:11 0:00 /sbin/getty -L ttyS1 9600 vt100
root 5518 0.6 7.1 21712 16112 ? Ss 10:12 0:12 /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf
admin 5684 3.1 8.8 25456 20000 ? S 10:13 0:56 /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf
admin 5719 2.9 8.6 25216 19552 ? S 10:13 0:53 /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf
root 5753 0.1 2.0 13840 4560 ? Ss 10:13 0:02 sshd: root@pts/0
root 5756 0.0 1.0 5712 2464 pts/0 Ss 10:13 0:00 -bash
root 5849 0.0 0.4 2912 1072 ? S 10:14 0:00 /usr/sbin/cnid_metad -l log_info -f /var/log/netatalk.log
root 7140 0.0 0.4 2624 1088 ? S 10:41 0:00 /usr/sbin/atalkd
root 7180 39.2 1.3 6640 2960 ? S 10:41 0:32 /usr/sbin/afpd -U uams_dhx.so,uams_dhx2.so,uams_clrtxt.so,uams_guest.so -c 50 -n READYNAS
Here's the (free -m) memory state before I try to connect, looks like there's still memory free:
total used free shared buffers cached
Mem: 221 215 5 0 15 164
-/+ buffers/cache: 35 185
Swap: 749 0 749
Here's the memory state after the connection drops:
Mem: 221 188 32 0 15 100
-/+ buffers/cache: 72 148
Swap: 749 0 749
AFP log doesn't seem to show anything out of the ordinary:
Jun 16 10:41:53.819241 afpd[7180] {logger.c:406} (D5:Logger): Setup file logging: type: Default, level: LOG_MAXDEBUG, file: /var/log/netatalk.log
Jun 16 10:41:53.888820 afpd[7180] {status.c:740} (I:AFPDaemon): "READYNAS"'s signature is <REMOVED>
Jun 16 10:41:53.889381 afpd[7180] {afp_config.c:347} (D5:AFPDaemon): DSIConfigInit: hostname: READYNAS, ip/port: default/548,
Jun 16 10:41:53.908459 afpd[7180] {dsi_tcp.c:316} (I:DSI): dsi_tcp_init: socket: Address family not supported by protocol
Jun 16 10:41:53.913890 afpd[7180] {afp_config.c:364} (N:AFPDaemon): AFP/TCP started, advertising <REMOVED>:548 (2-2-2-p3)
Jun 16 10:41:53.914271 afpd[7180] {auth.c:1146} (D5:AFPDaemon): uam: loading (/usr/lib/netatalk/uams_dhx.so)
Jun 16 10:41:53.995934 afpd[7180] {auth.c:1153} (D5:AFPDaemon): uam: uams_dhx.so loaded
Jun 16 10:41:53.996195 afpd[7180] {auth.c:1146} (D5:AFPDaemon): uam: loading (/usr/lib/netatalk/uams_dhx2.so)
Jun 16 10:41:53.999321 afpd[7180] {uams_dhx2_pam.c:925} (D5:UAMS): DHX2: generating mersenne primes
Jun 16 10:42:32.057337 afpd[7180] {auth.c:1153} (D5:AFPDaemon): uam: uams_dhx2.so loaded
Jun 16 10:42:32.057618 afpd[7180] {auth.c:1146} (D5:AFPDaemon): uam: loading (/usr/lib/netatalk/uams_guest.so)
Jun 16 10:42:32.059541 afpd[7180] {auth.c:1153} (D5:AFPDaemon): uam: uams_guest.so loaded
Jun 16 10:42:32.060143 afpd[7180] {auth.c:136} (I:AFPDaemon): uam: "No User Authent" available
Jun 16 10:42:32.060403 afpd[7180] {auth.c:136} (I:AFPDaemon): uam: "DHX2" available
Jun 16 10:42:32.060583 afpd[7180] {auth.c:136} (I:AFPDaemon): uam: "DHCAST128" available
Jun 16 10:42:32.060864 afpd[7180] {afp_config.c:580} (D5:AFPDaemon): Finished parsing Config File
Jun 16 10:42:32.061225 afpd[7180] {volume.c:1968} (D5:AFPDaemon): load_volumes: AFP MASTER
Jun 16 10:42:32.066636 afpd[7180] {volume.c:1247} (D10:AFPDaemon): readvolfile: seeding default umask: 0000
Jun 16 10:42:32.066876 afpd[7180] {volume.c:1259} (D5:AFPDaemon): readvolfile: "/etc/netatalk/AppleVolumes.system"
Jun 16 10:42:32.096475 afpd[7180] {volume.c:619} (D5:AFPDaemon): createvol: Volume 'homes'
Jun 16 10:42:32.097117 afpd[7180] {volume.c:661} (D10:AFPDaemon): createvol: Volume 'homes' -> UTF8-MAC Name: 'homes'
Jun 16 10:42:32.097397 afpd[7180] {volume.c:699} (D10:AFPDaemon): createvol: Volume 'homes' -> Longname: 'homes'
Jun 16 10:42:32.098239 afpd[7180] {acls.c:1786} (D5:AFPDaemon): Volume "/c/home" ACL support: yes
Jun 16 10:42:32.099862 afpd[7180] {vfs.c:1168} (D5:AFPDaemon): initvol_vfs: enabling EA support with native EAs
Jun 16 10:42:32.100443 afpd[7180] {volume.c:1247} (D10:AFPDaemon): readvolfile: seeding default umask: 0000
Jun 16 10:42:32.100664 afpd[7180] {volume.c:1259} (D5:AFPDaemon): readvolfile: "/etc/netatalk/AppleVolumes.default"
Jun 16 10:42:32.102026 afpd[7180] {volume.c:619} (D5:AFPDaemon): createvol: Volume 'backup'
Jun 16 10:42:32.102347 afpd[7180] {volume.c:661} (D10:AFPDaemon): createvol: Volume 'backup' -> UTF8-MAC Name: 'backup'
Jun 16 10:42:32.102567 afpd[7180] {volume.c:699} (D10:AFPDaemon): createvol: Volume 'backup' -> Longname: 'backup'
Jun 16 10:42:32.102968 afpd[7180] {acls.c:1786} (D5:AFPDaemon): Volume "/backup" ACL support: yes
Jun 16 10:42:32.104191 afpd[7180] {vfs.c:1168} (D5:AFPDaemon): initvol_vfs: enabling EA support with native EAs
Jun 16 10:42:32.104632 afpd[7180] {cnid.c:53} (I:AFPDaemon): Registering CNID module [dbd]
Jun 16 10:42:32.104832 afpd[7180] {cnid.c:53} (I:AFPDaemon): Registering CNID module [tdb]
Jun 16 10:42:32.105032 afpd[7180] {socket.c:445} (D5:Default): fdset_add_fd: adding fd 5 in slot 0
Jun 16 10:42:32.105253 afpd[7180] {socket.c:464} (D5:Default): fdset_add_fd: initialized with space for 87 conncections
Jun 16 10:42:32.105573 afpd[7180] {main.c:423} (D10:AFPDaemon): main: polling 1 fds
System Log doesn't show anything obvious either:
Jun 16 10:41:20 READYNAS avahi-daemon[1136]: Service "READYNAS (AFP)" (/etc/avahi/services/afp.service) successfully established.
Jun 16 10:41:20 READYNAS atalkd[7115]: zip_getnetinfo for eth0
Jun 16 10:41:21 READYNAS atalkd[7115]: done
Jun 16 10:41:21 READYNAS atalkd[7140]: Set syslog logging to level: LOG_INFO
Jun 16 10:41:21 READYNAS atalkd[7140]: restart (2-2-2-p3)
Jun 16 10:41:22 READYNAS atalkd[7140]: zip_getnetinfo for eth0
Jun 16 10:41:42 READYNAS last message repeated 2 times
Jun 16 10:41:52 READYNAS atalkd[7140]: config for no router
Jun 16 10:41:53 READYNAS atalkd[7140]: ready 0/0/0
Jun 16 10:47:02 READYNAS noflushd[1039]: Spinning down disks.
Jun 16 10:47:26 READYNAS noflushd[1039]: Disks spinning up after 0 minutes.
Swap: 749 0 749
Swap: 749 0 749
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-17
01:20 PM
2012-06-17
01:20 PM
Re: AFP drops connection with [T15]
I'm having the same problem; it happened when I upgraded from 10.6.8 to 10.7.4
I believe its the same problem as mentioned in this thread:
http://www.readynas.com/forum/viewtopic.php?f=28&t=62057
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-22
09:58 PM
2012-06-22
09:58 PM
It is - same SkySurfer!
I can't tell if it's related only to OSX or if it's related to the updates (since there have been AFP fixes in T15).
Either way, I'm hoping someone working at Netgear will help!
Message 3 of 3
