Orbi WiFi 7 RBE973
*OLD* ReadyNASOS 6.7.1-T252 (Beta 2) *OLD*
Skywalker
NETGEAR Expert
Latest beta: ReadyNASOS 6.7.1-T252 (Beta 2)
• ARM (102 / 104 / 2120 / 202 / 204 / 212 / 214)
• x86_64 (312 / 314 / 316 / 422 / 424 / 516 / 524 / 526 / 528 / 626 / 628 / 716 / 3130 / 3220 / 3312 /...
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
Changelog
  1. [Beta 1] Fixed an issue where quotas would get enabled after any share change, regardless of the volume quota setting.
  2. [Beta 1] Add support for automatic expansion of RAID 50 and 60 volumes in Flex-RAID mode after replacing all disks with larger ones.
  3. [Beta 1] Fixed GUI timeouts and general slowness in ADS mode when adding share-level Windows ACLs.
  4. [Beta 1] Fixed SMB access issue after non-admin users change their password.
  5. [Beta 1] Fixed an issue where the combination of quotas and either many snapshots or heavy fragmentation can result in I/O overhead and possibly running out of memory after snapshot deletion.
  6. [Beta 2] Fixed premature balance completed log message.
  7. [Beta 2] Fixed an issue where ReadyDR may start before the network is ready at boot time, causing the first job runs to fail.
  8. [Beta 2] Fixed missing USB storage capacity consumption statistics.
  9. [Beta 2] Cache SMART health statistics when disks are spun down. Temperature information will still be unavailable.
  10. [Beta 2] Fixed an issue where successful ReadyDR jobs would appear to have failed when using a non-English language setting.
WARNINGS:
  • Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
  • Devices updated with 6.7.1 firmware should not be downgraded to earlier firmware versions.
  • ReadyNAS 102, 104, and 2120 must not be updated directly to 6.7.x from 6.3.x or older firmware.  They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.7.x.
  • ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.7.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.7.x.
KNOWN ISSUES:
  • On some ARM systems, balance may take a very long time, depending on the filesystem's data layout.
Message 1 of 2
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.7.1-T244 (Beta 1)
Posted 6.7.1-T244 (Beta 1).
Message 2 of 2
Discussion stats
  • 1 reply
  • 6662 views
  • 2 kudos
  • 1 in conversation
Announcements
