Orbi WiFi 7 RBE973
ReadyNASOS 6.10.5 Beta
JohnCM_S
NETGEAR Employee Retired
• ARM
  • Supported devices: RN102 / RN104 / RN202 / RN204 / RN212 / RN214 / RN2120
• x86_64
  • Supported devices: RN312 / RN314 / RN316 / RN422 / RN424 / RN426 / RN516 / RN524X / RN526X / RN528X /  RN626X / RN628X / RN716X / RR2304 / RN3130 / RN3138 / RN3220 / RN4220 / RR3312 / RR4312X / RR4312S / RR4360X / RR4360S
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
Security Fixes
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes
This firmware addresses the following bugs:
• ClamAV fails to update database on ARM platform.
• Replicate keeps running even after the service is disabled.
• Root partition runs out of space when audit option is enabled for shares.
• Egnyte APT repository trusted key expires.
• Readynasd service crashes while parsing authorized replicate keys.
Warnings:
  • Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
  • Devices updated with 6.10.5 firmware should not be downgraded to firmware versions before 6.10.0.
  • ReadyNAS 102, 104, and 2120 systems must not be updated directly to 6.10.x from 6.3.x or older firmware. They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then to 6.10.x.
  • ReadyNAS 202, 204, 212 and 212 systems must not be updated directly to 6.10.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then to 6.10.x.
Message 1 of 1
Discussion stats
  • 0 replies
  • 2593 views
  • 0 kudos
  • 1 in conversation
Announcements
