× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
ReadyNASOS 6.8.0-RC1
OOM-9
NETGEAR Expert
Latest beta: ReadyNASOS 6.8.0-RC1
• ARM (102 / 104 / 2120 / 202 / 204 / 212 / 214)
• x86_64 (31X / 42X / 516 / 52X / 62X / 716 / 3130 / 3220 / 3312 / 4220 / 4312 / 4360)
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
New Features
  • File Search through the admin interface (not available on RN102 or RN104)
  • HTTP/HTTPS Proxy support for built in services (remote firmware updates, ReadyCLOUD, and app install/update)
  • Share NFS User ID Mapping Configuration
  • Featured Apps
  • Categorized ReadyNAS Available Apps
  • Enhancements for macOS
  • Multiple admin account support, using the admin group
Changelog
  1. [Beta 1] FlexRAID allow formatting multiple disks in one operation.
  2. [Beta 1] Under the Performance section, the PSU and UPS are shown as separated items to help devices with larger disk capacity units.
  3. [Beta 2] Fixed false failure status in backup job "Test Connection" functionality with NFS backup jobs.
  4. [Beta 2] Fixed "Safe Mode" fallback for web admin interface.
  5. [Beta 2] Update Skylake CPU microcode. (RR3312/4312/4360)
  6. [Beta 2] Fixed intermittent WD Gold disk detection failure. (RR4360)
  7. [Beta 2] Fixed Stack Clash vulnerability (CVE-2017-1000364 and friends).
  8. [Beta 3] Fixed issues with search queries containing special characters.
  9. [Beta 3] Fixed an issue where a RAID reshape may not continue after rebooting.
  10. [Beta 3] Fixed security issues in Apache (CVE-2017-7679, CVE-2017-3167, CVE-2017-3169, CVE-2017-7668).
  11. [Beta 3] Delay automatic poweroff if a ReadyDR job is in process.
  12. [Beta 3] Fixed false PSU offline alerts. (RN3220/4220, RR3312/4312/4360)
  13. [Beta 3] Fixed an issue where static network configuration on VLANs of bonded interfaces would reset after reboot.
  14. [Beta 3] Fixed failure to switch a volume with multiple RAID groups from Striped to Concatenated mode.
  15. [Beta 3] Fixed ReadyDR failures on shares with non-ASCII characters.
  16. [RC1] Fixed potential file system metadata corruption on ReadyDR destination systems with multiple jobs and quotas enabled.
  17. [RC1] Several GUI improvements to the handling of secondary admin accounts.
  18. [RC1] Fixed incremental backup jobs backing up to remote OSX machines over SMB.
  19. [RC1] Fixed UNIX permissions of files synced with Cloud Storage.
  20. [RC1] Fixed GUI performance issues in ADS mode with trusted domains when using share-level ACLs.
  21. [RC1] Fixed GUI opening the wrong tab when clicking the Volume Schedule button.
WARNINGS:
  • Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
  • Devices updated with 6.7.1 firmware should not be downgraded to earlier firmware versions.
  • ReadyNAS 102, 104, and 2120 must not be updated directly to 6.8.x from 6.3.x or older firmware.  They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.8.x.
  • ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.8.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.8.x.
KNOWN ISSUES:
  • None
Message 1 of 4
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.8.0-T54 (Beta 2)
Posted 6.8.0-T54 (Beta 2).
Message 2 of 4
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.8.0-T66 (Beta 3)
Posted 6.8.0-T66 (Beta 3).
Message 3 of 4
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.8.0-RC1
Posted 6.8.0-RC1.
Message 4 of 4
Discussion stats
  • 3 replies
  • 9019 views
  • 7 kudos
  • 2 in conversation
Announcements
