Orbi WiFi 7 RBE973
Turbo mode
Iridahonda
Turbo mode
Is anyone able to get turbo to run on their machine?  i7z is telling me its enabled (recompiled kernel) but I dont see anything above the standard 2.5Ghz even when fully loaded on a single core.  Anyone got any ideas?
Cpu speed from cpuinfo 2494.00Mhz
cpuinfo might be wrong if cpufreq is enabled. To guess correctly try estimating via tsc
Linux's inbuilt cpu_khz code emulated now
True Frequency (without accounting Turbo) 2494 MHz
  CPU Multiplier 25x || Bus clock frequency (BCLK) 99.76 MHz
Socket [0] - [physical cores=4, logical cores=8, max online cores ever=4]
  TURBO ENABLED on 4 Cores, Hyper Threading ON
  Max Frequency without considering Turbo 2593.76 MHz (99.76 x [26])
  Max TURBO Multiplier (if Enabled) with 1/2/3/4 Cores is  35x/34x/32x/31x
  Real Current Frequency 2493.96 MHz [99.76 x 25.00] (Max of below)
        Core [core-id]  :Actual Freq (Mult.)      C0%   Halt(C1)%  C3 %   C6 %   C7 %  Temp      VCore
        Core 1 [0]:       2417.57 (24.23x)         1       0       1    99.2       0    38      0.9507
        Core 2 [1]:       2475.99 (24.82x)         1       0       1    99.5       0    27      0.9507
        Core 3 [2]:       2493.96 (25.00x)       100       0       1       0       0    40      0.9507
        Core 4 [3]:       2493.57 (25.00x)         1       0       1    99.3       0    37      0.9657
C0 = Processor running without halting
C1 = Processor running with halts (States >C0 are power saver modes with cores idling)
C3 = Cores running with PLL turned off and core cache turned off
C6, C7 = Everything in C3 + core state saved to last level cache, C7 is deeper than C6
Model: RN51600|ReadyNAS 516 6-Bay
Message 1 of 1
Discussion stats
  • 0 replies
  • 3853 views
  • 0 kudos
  • 1 in conversation
Announcements
