Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
4.2.13 ultra 6 not powering up automatically
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-09-22
03:14 AM
2010-09-22
03:14 AM
Just a note to record that only the auto power off works and even though the log shows a restart is scheduled it never actually restarts. Thanks
Message 1 of 128
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-09-23
12:00 AM
2010-09-23
12:00 AM
Re: 4.2.13 ultra 6 not powering up automatically
Looks like WOL isn't working either
Message 2 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-09-30
09:02 AM
2010-09-30
09:02 AM
Any solution to this in 4.2.14?
Message 3 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-09-30
11:35 AM
2010-09-30
11:35 AM
There are multiple threads on this subject already.
Download system logs (FrontView>Status>Logs>Download All Logs). Open bios_ver.log, tell me what the contents say.
Message 4 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-09-30
11:40 AM
2010-09-30
11:40 AM
It says:-
05/26/2010 FLAME6-2 V1.1
many thanks
many thanks
Message 5 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-09-30
11:56 AM
2010-09-30
11:56 AM
Thanks, that is the latest BIOS code.
Willing to try 4.2.14-T14 ?
Message 6 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-09-30
01:16 PM
2010-09-30
01:16 PM
Absolutely!
I'll let you know tomorrow if it worked. Thanks
Message 7 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-09-30
10:29 PM
2010-09-30
10:29 PM
Still not working using 4.2.14-T14
As before, the Ultra 6 shut off at 22.00 and noted a schduled power-on for 6.00am. It didn't start so I manually started it at 6.25am.
See extract from log below:-
Fri Oct 1 06:25:49 WEST 2010 System is up.
Thu Sep 30 22:00:26 WEST 2010 System power-on scheduled for 10/01/2010 06:00
Thu Sep 30 14:53:25 WEST 2010 System is up.
Thu Sep 30 14:53:17 WEST 2010 Your ReadyNAS device has been updated with a new firmware image. (RAIDiator-x86 4.2.14-T14)
Message 8 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-09-30
10:35 PM
2010-09-30
10:35 PM
K thanks, will check more with developers in the morning.
Message 9 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-01
02:36 PM
2010-10-01
02:36 PM
Chirpa, is the BIOS updated (if needed) as part of the RAIDIATOR install package? I've never seen a separate Readynas BIOS update.
Message 10 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-07
10:11 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-17
02:20 AM
2010-10-17
02:20 AM
Still not working in 4.2.15. Does this affect everyone or is my Ultra 6 faulty?
Message 12 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-25
03:29 AM
2010-10-25
03:29 AM
My ultra 6 has the same issue, will power off but not come back on at the scheduled time. Also can't seem to get wake on LAN working either. Thought it was just my settings, might be an issue with Ultra's. .. Any advice would be appreciated.
Message 13 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-31
10:30 AM
2010-10-31
10:30 AM
wireworld wrote: Looks like WOL isn't working either
Same problem here, timed powerup not working, WOL not working. 😞
Ultra 6, fully updated firmware.
Message 14 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-01
05:07 PM
2010-11-01
05:07 PM
Ultra 6 users experiencing this issue...
Ultra 6 users experiencing this issue:
Download your system logs (FrontView>Status>Logs>Download All Logs). Open bios_ver.log.
If the date in there is before 06/10/10, send me a PM (private message) with your full mailing address (no PO boxes) (and phone number if outside of domestic USA), and I will ship you a USB key which will flash to the BIOS to the latest version (06/10/10).
If you are familiar with Linux/OSX, I can give you a download-able image instead if preferred.
Writing the boot image via Windows is un-reliable, which is why I can ship you the pre-made keys instead (and you get a NETGEAR USB flash key to keep after the BIOS flash is done :))
Message 15 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-06
01:13 AM
2010-11-06
01:13 AM
Just a note to say USB key arrived, bios flashed and now the timer appears to work correctly.
many thanks
many thanks
Message 16 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-06
01:33 AM
2010-11-06
01:33 AM
Great! Does WOL now work as well for you?
Message 17 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-09
01:25 AM
2010-11-09
01:25 AM
Doesn't seem to be working although I can't be absolutely sure that the protocol and port I'm using are correct.
Message 18 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-09
01:34 AM
2010-11-09
01:34 AM
I might need to give it a try sometime. I received the USB key yesterday. I've updated the BIOS on the NAS so I should be able to give it a try.
Message 19 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-09
07:55 AM
2010-11-09
07:55 AM
let us know how it goes with WOL.
Message 20 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-09
12:34 PM
2010-11-09
12:34 PM
What WOL client do you recommend to run on a Mac, to send the wake-up command to the ReadyNAS?
Message 21 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-09
10:09 PM
2010-11-09
10:09 PM
I used "WakeOnLan" by Dirk Lembens for MAC & Aquila Technology's WOL Windows Apps. They are simple to use and it works fine in both Windows and Mac Enviroment.
Message 22 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-10
08:38 PM
2010-11-10
08:38 PM
For WOL to work do you need to shutdown the ReadyNAS using the power timer? I couldn't get it to work just now even over a direct-connection when I shut it down manually.
Message 23 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-10
08:59 PM
2010-11-10
08:59 PM
WOL not working for me using power timer to shutdown first either. I'm using the Mac app Jedi Knight recommended.
Message 24 of 128
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-11-15
01:55 AM
2010-11-15
01:55 AM
I've tried the recommended Windows program and WOL is not working.
Message 25 of 128
