× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
6.4.1-RC1 rsync error
olest
Guide
Still gets an error with rsync backup on 6.4.1-RC1
ackup Start Time: Sat Nov 21 2015 9:18:19
Backup Finish Time: Sat Nov 21 2015 9:18:34
Backup Status: Fail: failure during copy.
Failed to run rsync, return rc 2560 (10)
'rsync' command returns rc=2560
building file list ... done
rsync: on remote machine: -vlOJogDtrxe.iLsfx: unknown option
rsync error: requested action not supported (code 4) at clientserver.c(906) [Receiver=3.0.7]
rsync: read error: Connection reset by peer (104)
rsync error: error in socket IO (code 10) at io.c(785) [sender=3.1.1]
Message 1 of 15
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: 6.4.1-RC1 rsync error
Please try 6.4.1-RC3
Message 13 of 15
All Replies
JennC
Hello olest,
What are the apps running on the NAS at the same time when using rsync?
Message 2 of 15
olest
Guide
The only other installed app is PLEX
Message 3 of 15
JennC
Hello olest,
Do you also have AntiVirus enabled? Disable please both AntiVirus and Plex and see if the same.
Message 4 of 15
olest
Guide
Antivirus is not enabled.
Same error with PLEX off (disabled)
Message 5 of 15
mdgm-ntgr
Perhaps try updating Rsync on the other machine to Rsync 3.1.1 and see if that helps?
Message 6 of 15
olest
Guide
The other machine is a QNAP NAS with newest firmware so I can not update rsync on it.
It worked with 6.2.4 firmware.
Message 7 of 15
bugsplat
Tutor
I was getting the same rsync error messages when I updated from 6.4.0 on my RN314.  Rsync backups to a Duo v1 worked fine until I updated the RN314 to 6.4.1 T21, so I had to fall back to 6.4.0 to get the rsync backups to work again.
I haven't tried 6.4.1 T39 or 6.4.1-RC1, but by the look of things, rsync still has problems for us.
Message 8 of 15
Guru
Rsync backup jobs running on my RN102 and RN202 with the source being my pro-6 running 4.2.28 are working fine.
Having you tried running the backup jobs on the both the Duo and the RN312?
Message 9 of 15
Skywalker
NETGEAR Expert
Can you post the related entry in /etc/frontview/backup_jobs.conf (with any sensitive information removed, of course)?  Or you can PM it to me.
Message 10 of 15
olest
Guide
<backupJob>
<job_id>007</job_id>
<name>Rsync OSDATA til TS269L</name>
<enabled>1</enabled>
<sch_every>24</sch_every>
<sch_start>2</sch_start>
<sch_end>23</sch_end>
<sch_dow>127</sch_dow>
<src_type>share</src_type>
<src_share_proto>OSDATA</src_share_proto>
<src_share_vol>data</src_share_vol>
<src_path></src_path>
<src_login></src_login>
<src_password></src_password>
<src_port>0</src_port>
<src_eject>0</src_eject>
<dst_type>remote</dst_type>
<dst_share_proto>rsync</dst_share_proto>
<dst_share_vol></dst_share_vol>
<dst_path>192.168.1.4::RN312-backup/</dst_path>
<dst_login>mylogin</dst_login>
<dst_password>mypass</dst_password>
<dst_port>0</dst_port>
<dst_eject>0</dst_eject>
<opt_full_backup_freq>FIRST_TIME</opt_full_backup_freq>
<opt_remove_previous_backup>0</opt_remove_previous_backup>
<opt_chown_to_share_owner>0</opt_chown_to_share_owner>
<opt_rsync_options>0</opt_rsync_options>
<opt_email_this_to_alert_email>0</opt_email_this_to_alert_email>
<opt_rsync_exclude></opt_rsync_exclude>
<opt_misc_option>0</opt_misc_option>
<wol_addr></wol_addr>
</backupJob>
Message 11 of 15
Skywalker
NETGEAR Expert
Thanks.  I am able to reproduce the issue.  We'll have this fixed in 6.4.1.
Message 12 of 15
mdgm-ntgr
Message 13 of 15
olest
Guide
Looks like RC3 works - my backup is running right now.
Message 14 of 15
bugsplat
Tutor
Yup, 6.4.1-RC3 fixed the rsync backup problems (to the Duo v1) for me too.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 6473 views
  • 0 kudos
  • 6 in conversation
Announcements
