- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with backup jobs reporting on RN102 and RN104 after update to FW6.4.0 final
- Mark as New
- Bookmark
- Subscribe
- Permalink
After updating 3 NAS (1 RN102, 1RN104 and 1RN314) is RN314 OK, but 2others (RN102 and RN104) got problems with Backup Job reportings.
Job name In this case is "Documents_Personal_Cajo7n"
I make job and after 1st run (or after 1st run after deleting log for existing backup job):
I got this in e-mail:
Successfully completed backup job Documents_Personal_Cajo7n.
and this is in jobs log:
Backup Job Name: Documents_Personal_Cajo7n
Backup Job Type: Full
Protocol: cifs
Backup Source: [Documents]/Personal
Backup Destination: [remote:cifs]///192.168.77.2/Documents/personal
Backup Start Time: Fri Oct 9 2015 7:46:23
Backup Finish Time: Fri Oct 9 2015 7:46:25
Backup Status: Success
after 2nd run (or after 2nd run after deleting log for existing backup job):
Successfully completed backup job Documents_Personal_Cajo7n. -------- Backup Job Information -------- Backup Job Name: Documents_Personal_Cajo7n Backup Job Type: Full Protocol: cifs Backup Source: [Documents]/Personal Backup Destination: [remote:cifs]///192.168.77.2/Documents/personal Backup Start Time: Fri Oct 9 2015 7:46:23 Backup Finish Time: Fri Oct 9 2015 7:46:25 Backup Status: Success
Backup Job Type: Incremental
Protocol: cifs
Backup Start Time: Fri Oct 9 2015 7:47:15
Backup Finish Time: Fri Oct 9 2015 7:47:16
Protocol: cifs
after 3rd run (or after 3rd run after deleting log for existing backup job):
Successfully completed backup job Documents_Personal_Cajo7n. -------- Backup Job Information -------- Backup Job Name: Documents_Personal_Cajo7n Backup Job Type: Incremental Protocol: cifs Backup Source: [Documents]/Personal Backup Destination: [remote:cifs]///192.168.77.2/Documents/personal Backup Start Time: Fri Oct 9 2015 7:47:15 Backup Finish Time: Fri Oct 9 2015 7:47:16 Backup Status: Success
Protocol: cifs
Backup Start Time: Fri Oct 9 2015 7:48:36
Backup Finish Time: Fri Oct 9 2015 7:48:37
Protocol: cifs
Protocol: cifs
It seems to me as if NAS is sending "1 log BACK".
For 1st run send nothing.
For 2nd run send info from 1st run (look at the start and finish times)
After 3rd run unit send data (log info) from 2nd run. And so on for othe runs...
Report sending by e-mail i -1 run.
It is same for all backup jobs on both RN10x NASes, type of backup job (rsync, share) and source/destination does not make any differences in behaviour.
Delete and create new jobs on 6.4.0 make no diference in behaviour of NASes.
If is job run manually or automatically (scheduled) - no difference in reporting situation.
Only thing that make difference is ERASE LOG for the job.
On RN314 unit is all OK.
Can someone look at this problem? I need to get accurate data for e-mail report. If job repeates 1 time in 24hrs, i get 1 day old report.
Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Root cause was found and this issue is fixed, will be released in next firmware. Thank you.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Problem with backup jobs reporting on RN102 and RN104 after update to FW6.4.0 final
and some other info on RN10x units:
apps running: SMB plust, istat, PHPSysinfo.
Antivirus disabled, some shares have snapshots. Raid is on RN104 40% free, on RN102 about 60% free.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some new facts.
Some job sent logs from LAST backup Befor update to FW 6.4.0., some 1 -2 days old.
RN314 is affected as well. Sending 1 - 2 days old logs for backup jobs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
..still waiting for help or answer....is there any workaround or patch for this reporting error?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for reporting this issue, Kardano. Could you please let us know
1. What was the old firmware version before you upgraded it to 6.4.0 final release?
2. Did this issue exist before you upgraded to 6.4.0 release?
3. Could you please confirm that the issue only exsits in your RN1x not RN314 devices?
4. Could you please enable remote support at System->Settings->Support and then tell us the port number? So that we can get more info for your device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
enabled od RN104 (my unit) (2pcs RN102 and 1 RN314 are my customers)
all NASes have production data.
One RN104 and two RN102 units was FW 6.2.5 (final), RN314 was FW 3.2.4 (final) no betas were tested. All NASes are in production enviroment.
No. All was OK, there was no problem with any units except my RN104 wich has problem with defrag. (after checing by MDGM told me to wait until update to FW 6.4.0 which solved my defrag problem on this NAS.
As I added later, issue is affecting all NASes. I can confirm that 314 is affected with rhis issue and sending logs for backup jobs with data 1 pass back (previous run of the backup job)
Enabled on 1 RN104 with comment "KARDANO104" port 51274
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the info, Kardano. Our engineering team is working on the issue and I will get back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your hel. I'll wait for new FW.
Thanks
