× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
*OLD* ReadyNASOS 6.7.3-T283 (Beta 1) *OLD*
Skywalker
NETGEAR Expert
Latest beta: ReadyNASOS 6.7.3-T283 (Beta 1)
• ARM (102 / 104 / 2120 / 202 / 204 / 212 / 214)
• x86_64 (312 / 314 / 316 / 422 / 424 / 426 / 428 / 516 / 524 / 526 / 528 / 626 / 628 / 716 / 3130 / 3...
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
Changelog
  1. [Beta 1] Fixed an issue where heavy I/O could result in a hang, possibly referencing "bfq_lookup_next_entity" on the LCD.
  2. [Beta 1] Present missing volumes in the GUI, so the records can be deleted.  This can help restore app and home directory functionality if the removed volume previously held apps.
  3. [Beta 1] Fixed an issue where the volume may fail to mount, if a file or directory with a matching name exists on the root filesystem.
  4. [Beta 1] Backport various upstream file system fixes.
  5. [Beta 1] Add Bonjour discovery protocol support, which is required for TiVo Bolt.
  6. [Beta 1] Incorporated several security updates for various OS packages.
WARNINGS:
  • Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
  • Devices updated with 6.7.1 firmware should not be downgraded to earlier firmware versions.
  • ReadyNAS 102, 104, and 2120 must not be updated directly to 6.7.x from 6.3.x or older firmware.  They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.7.x.
  • ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.7.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.7.x.
KNOWN ISSUES:
  • None
Message 1 of 2
Skywalker
NETGEAR Expert
Re: ReadyNASOS 6.7.3-T283 (Beta 1)
Posted 6.7.3-T283 (Beta 1).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4614 views
  • 1 kudo
  • 1 in conversation
Announcements
