- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Suddenly (on latest beta 6.4.0 Beta4) rsync starts to fail...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been using rsync for incremental backups on a RN102 pulling data from an RN314 unit. Suddenly on one particular file rsync starts to fail:
Backup Job Name: från BIGHUB RSYNC-mappen
Backup Job Type: Incremental
Protocol: rsync
Backup Source: [remote:rsync]/mchome.dyndns-home.com::Backup/RSYNC/
Backup Destination: [Backup]/RSYNC
Backup Start Time: Sun Sep 13 2015 15:32:41
Backup Finish Time: Sun Sep 13 2015 15:45:20
Backup Status: Fail: failure during copy.
Failed to run rsync, return rc 2560 (10)
'rsync' command returns rc=2560
HP-ARBETSRUMMET/Outlook/
MARCUS-LAPTOP/Outlook/archive.pst
rsync: [generator] write error: Connection reset by peer (104)
rsync error: error in socket IO (code 10) at io.c(820) [generator=3.1.1]
This started the same day as I installed the 6.4.0 beta4 on the system (both units). I checked if compression on/off would change the situation but it occurss independently of the setting of rsync compression.
I similar error occurred on another file (a media MP4 file though) that previously had copied correctly. I however deleted that file from the source so that particular problem is no longer an issue.
So something with the latest 6.4.0 release might have caused rsync to become unstable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Suddenly (on latest beta 6.4.0 Beta4) rsync starts to fail...
Is your PST actively mounted in outlook? If so, then that file is not readable and will cause a backup job to fail.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is not that problem. The rsync job runs between two NASes and with no client (eg outlook machine) accessing them
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try copying the file manually (CIFS or NFS)
- Mark as New
- Bookmark
- Subscribe
- Permalink
The transfer @marcusclaus is doing is over the internet as per the job details.
How large are the files that it can't transfer? I can see about reproducing. I have like 3 PSTs that range between 1 GB and 3 GB I can try with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I missed that.
If he has remote access to the source it still might be worth copying the problematic file manually (maybe to another share).
Seems to me a btrfs checksum failure could do something like this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I deleted the 2,9 GB archive.pst file. The same problem happen. Before 6.4.0 firmware upgrade the rsync worked. But not anymore.
Protocol: rsync
Backup Source: [remote:rsync]/192.168.1.2::Backup/RSYNC/
Backup Start Time: Mon Oct 12 2015 15:37:38
Backup Finish Time: Mon Oct 12 2015 16:01:09
rsync error: received SIGUSR1 (code 19) at main.c(1434) [receiver=3.1.1]
from other posts, there seem to be several rsync related bugs now in 6.4.0....
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried the Beta release 6.4.1. The problem is the same, I get timeouts on my rsync job coppying from pc to ReadyNas. What I also noticed since 6.4.1, the access to some folders is very slow, some times more than 20s. With 6.2.5 the access time was hardly ever more than 2s.
