- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Volume: System volume root's usage is 94%
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Just wondering after doing an 6.4.0 beta 2 update, I decided to look into the logs and found this error occuring heaps .
Volume: System volume root's usage is 94%. This condition should not occur in normal conditions. Contact technical support.
The hard drive itself are 80% full. Is there a clean up procedure I should follow to make more room or I should not worry about it?
Thanks
for any suggestions.
Slav
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Volume: System volume root's usage is 94%
This is definitely something to worry about. If the OS partition gets full you will see some unpredictable behaviour.
You need to look into why the root volume is that full and address it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You should be worrying about it. The NAS can end up bricked if the root volume fills.
The root volume is NOT the same as the data volume (and you can't see it w/o ssh).
So contact technical support. The usual cause is a mis-installed app that is using the root volume for storage. Though there are other possibilities, including a run-away log file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree with StephenB re a mis-installed app. I had the root filling up on 6.3.3.beta due to Logitech Media Server installation. Although there is a workaround using SSH on the forums, which I did temporarily, in the end I reset to factory default and did not install LMS next time. No problem subsequently (6.3.5, 6.4.0 Beta 2 and 3).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah okay i noticed it is filling up since about August, when I look at the logs.
Thanks will check it out .
Slav
- Mark as New
- Bookmark
- Subscribe
- Permalink
MDGM has averted disaster.
Thank you for that
SLav
