× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
4.1.9[T10]-Slow AFP write speed
downinitjr
Am I the only one seeing AFP write speeds drop in these betas after [T2]? With [T2] AFP write speeds are around 35MB/s, using [T6-T10] write speeds have dropped to around 10-12MB/s.
Message 1 of 13
jdroh
Re: 4.1.9[T10]-Slow AFP write speed
I'm seeing a slowdown on my Duo using AFP.
I'm running with Jumbo frames over a gigabit network switch.
Lion Finder Drag and drop copy speeds as reported by Activity monitor
4.1.9-T10 Write 13.7 MB/sRead 50 MB/s
4.1.9-T2 Write 25 MB/s/Read 55-60 MB/s
Message 2 of 13
stevesreed
On my X6, T10 is about 1/3 the write speed of T2 for me. I'm using a 2.8Ghz Core 2 Duo iMac, OSX 10.7.3, jumbo packets, gigabit Ethernet
Using the shell command "dd if=/dev/zero of=foo bs=1024k count=512", I got 31045392 bytes/second write with T2, but only 11739606 bytes/second with T10.
Read speed was fairly close (42745905 bytes/sec for T2, 40373720 bytes/sec for T10)
Message 3 of 13
armandckj
Hi,
I also have slow write speeds.
Test results with Helios Lantest UB
4.1.8-T9
write afp 33MB/s
read afp 55MB/s
write nfs 14MB/s
read nfs 44MB/s
write smb 21MB/s
read smb 37MB/s
4.1.9-T6
write afp 14MB/s 😞
read afp 55MB/s
write nfs 14MB/s
read nfs 45MB/s
write smb 14MB/s 😞
read smb 37MB/s
Both afp and smb slower.
4.1.9-T9
same as T6.
I have not tried T2 or T10 yet.
Armand
Message 4 of 13
yoh-dah
Guide
Armand, I'd be interested to see your dd write performance via SSH if you have shell access to the box. You would need to do something like:
# cd /c
# time dd if=/dev/zero of=foo bs=1024k count=1024
Message 5 of 13
armandckj
rn-d-vl27:/c# time dd if=/dev/zero of=foo bs=1024k count=1024
1024+0 records in
1024+0 records out
1073741824 bytes transferred in 37,243286 seconds (28830480 bytes/sec)
real 0m37.321s
user 0m0.010s
sys 0m30.900s
rn-d-vl27:/c#
Is this good or bad?
Armand
Message 6 of 13
armandckj
Complete Helios Lan test UB output
AFP, 4.1.8-T9
Create 300 files a 20 kB: 8,08 sec
Open/close 300 files: 1.07 sec
Remove 300 files: 3,68 sec
Write 300 MB to file: 34.99 MB/sec
Read 300MB from file: 55.90 MB/sec
Lock/Unlock 16000 times: 43.64 sec
Read directory/640 files: 0.96 sec
10 passes take more than 10 minutes.
AFP, 4.1.9-T9
Create 300 files a 20 kB: 8,48 sec
Open/close 300 files: 1.06 sec
Remove 300 files: 3,79 sec
Write 300 MB to file: 14.76 MB/sec
Read 300MB from file: 54.81 MB/sec
Lock/Unlock 16000 times: 44.09 sec
Read directory/640 files: 0.91 sec
10 passes take more than 10 minutes. Only write speeds seems affected.
NFS, 4.1.8-T9
Create 300 files a 20 kB: 2.38 sec
Open/close 300 files: 0.15 sec
Remove 300 files: 0.82 sec
Write 300 MB to file: 14.14 MB/sec
Read 300MB from file: 44.91 MB/sec
Lock/Unlock 16000 times: 0.06 sec
Read directory/640 files: 0.28 sec
10 passes takes less than 4 minutes.
NFS, 4.1.9-T9
Create 300 files a 20 kB: 2.35 sec
Remove 300 files: 0.78 sec
Write 300 MB to file: 14.24 MB/sec
Read 300MB from file: 44.56 MB/sec
Read directory/640 files: 0.26 sec
10 passes takes less than 4 minutes. Not affected.
Does this help?
Armand
Message 7 of 13
yoh-dah
Guide
Thanks for the detailed report Armand. I think we should have a fix for that in the next update soon.
Message 8 of 13
hibernian56
Just as bad in 4.1.9-T14
Message 9 of 13
mdgm-ntgr
NETGEAR Employee Retired
What about T15?
Message 10 of 13
downinitjr
I've had much better results with T15. Write speeds are around 36-37MB/sec. now. I
Message 11 of 13
jdroh
4.1.9[T15] is much better
I'm having much better performance with T15 as well
10 GB File Finder copy OS10.7
Full Data Journaling Disabled
Journaling Enabled
56 MB/s read
25 MB/s write
Journaling Disabled
61 MB/s
37.5 MB/s
Message 12 of 13
hibernian56
I don't know how but I didn't notice T15 until mdgm suggested it!! I'm downloading now, thanks for the heads up.
By the way, has anyone tried SMB in 10.7.4 yet?
I upgraded last night, but have already changed all my libraries (iTunes, Plex etc.) to point at AFB sources. I don't want to have to change back to SMB to discover its just as flaky as before.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 5777 views
  • 0 kudos
  • 7 in conversation
Announcements
