× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
6.10.5-T11 (Beta 1) apt upgrade error
amazz20
Guide
This may or may not be anything, it hasn't caused any issues on my RN202, and have had such things happen before during beta phases.
Just thought I would post it if it helps.
 root@ezekiel:/home/admin# apt upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up nfs-kernel-server (1:1.2.8-9+deb8u1) ...
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.)
debconf: falling back to frontend: Readline
update-rc.d: error: initscript does not exist: /etc/init.d/nfs-kernel-server
dpkg: error processing package nfs-kernel-server (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
nfs-kernel-server
E: Sub-process /usr/bin/dpkg returned an error code (1)
Model: RN202|ReadyNAS202 2-Bay
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 1090 views
  • 0 kudos
  • 1 in conversation
Announcements
