- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
6.10 beta 2 - errors updating udev
- Mark as New
- Bookmark
- Subscribe
- Permalink
received below errors while doing apt-get upgrade
Setting up udev (230-7~bpo8+2.netgear3) ...
addgroup: The group `input' already exists as a system group. Exiting.
dpkg: error processing package udev (--configure):
subprocess installed post-installation script returned error exit status 102
Errors were encountered while processing:
udev
E: Sub-process /usr/bin/dpkg returned an error code (1)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys,
If you stuck on the udev problem, you might try this.
KenKen
edit the file
/var/lib/dpkg/info/udev.postinst
either vi or other text editor (I use nano)
add to the first line
exit 0
run apt update & apt upgrade again
You can remove the line and resume normal after finish.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 6.10 beta 2 - errors updating udev
apt-get upgrade is a very dangerous thing to do on a NAS. You do not know what parts of the NAS specific OS may stop functioning with an update to the Linux core.
Why do you thnk you need to do it at all?
- Mark as New
- Bookmark
- Subscribe
- Permalink
its been normally safe for os 6, and these are netgear packages that are failing to update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there going to be a new beta sooon?
Is there any way to unmuck my apt-get packages?
somehow while trying to get this stupid udev error cleared I have lost several install packages and have a mess of jacked up dependencies now.
I probably made things worse by attempting to install beta 2 over itself.
I have lost python and other packages and still get stuck on udev.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried a different nas that is completely stock, that is running 6.10 beta2.
apt-get update/upgrade fails with with clamav daemon version mismatches.
I removed clamav
cd /var/lib/dpkg/info rm clamav* apt purge clamav*
do another apt-get update, then apt-get upgrade and see this, which is what I saw before I started having UDEV problems on my main nas.
root@frodo:/var/lib/dpkg/info# apt-get update Hit:1 http://security.debian.org jessie/updates InRelease Get:2 http://download.zerotier.com/debian/jessie jessie InRelease [17.8 kB] Ign:3 http://mirrors.edge.kernel.org/debian jessie InRelease Hit:4 https://apt.readynas.com/packages/readynasos 6.10.0 InRelease Hit:5 http://mirrors.edge.kernel.org/debian jessie Release Fetched 17.8 kB in 0s (26.6 kB/s) Reading package lists... Done root@frodo:/var/lib/dpkg/info# apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages have been kept back: apache2 apache2-bin apache2-data apache2-utils The following packages will be upgraded: btrfs-tools freeapp-collection libnss-myhostname libnss-winbind libsmbclient libssl1.0.0 libsystemd0 libudev1 libwbclient0 mdadm openssl samba samba-common samba-common-bin samba-libs samba-vfs-modules smbclient systemd systemd-sysv tzdata udev winbind 22 upgraded, 0 newly installed, 0 to remove and 4 not upgraded. Need to get 14.1 MB of archives. After this operation, 42.9 MB of additional disk space will be used. Do you want to continue? [Y/n] n Abort.
there is a lot of system packages wanting to be updated that probably should not be ?
I believe when I hit Y (without looking carefully at the upgrading package), is where my problems with UDEV started.
I am not jacking up another nas to experiment further, I still need to get my main nas back to working properly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys,
KenKen
edit the file
exit 0
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks a ton, I was finally able to get everything up to date and fixed.
