Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
6.5.0-T338 BETA 2 - VirtualBox issues since upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-03-26
07:59 AM
2016-03-26
07:59 AM
Hi All,
Since upgrading to 6.5.0 Beta 2 I can't get virtual box to work, any thoughts?
root@NAS:/data/VirtualBox# /sbin/rcvboxdrv setup /sbin/rcvboxdrv: 35: /sbin/rcvboxdrv: /sbin/modprobe: not found Stopping VirtualBox kernel modules/sbin/rcvboxdrv: 155: /sbin/rcvboxdrv: lsmod: not found /sbin/rcvboxdrv: 155: /sbin/rcvboxdrv: lsmod: not found /sbin/rcvboxdrv: 155: /sbin/rcvboxdrv: lsmod: not found ...done. Uninstalling old VirtualBox DKMS kernel modules ...done. Removing old VirtualBox pci kernel module ...done. Removing old VirtualBox netadp kernel module ...done. Removing old VirtualBox netflt kernel module ...done. Removing old VirtualBox kernel module ...done. Trying to register the VirtualBox kernel modules using DKMSError! Problems with depmod detected. Automatically uninstalling this module. DKMS: Install Failed (depmod problems). Module rolled back to built state. ...failed! (Failed, trying without DKMS) Recompiling VirtualBox kernel modules ...failed! (Look at /var/log/vbox-install.log to find out what went wrong)
From the logs.
/bin/sh: 3: depmod: not found
make: *** [install] Error 127
Solved! Go to Solution.
Model: RN51600|ReadyNAS 516 6-Bay Diskless
Message 1 of 4
Labels:
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-03-27
04:18 AM
2016-03-27
04:18 AM
Quick update. I just got this working.
Found issue was with busybox-kmod
removed busybox-kmod and install just kmod.
VirtualBox is now working like a charm 🙂
Message 4 of 4
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-03-26
01:12 PM
2016-03-26
01:12 PM
Re: 6.5.0-T338 BETA 2 - VirtualBox issues since upgrade
You seem to be missing som binarys, they might be locked to the super user.
Have you tried running the command with "su" s prefix?
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-03-26
01:19 PM
2016-03-26
01:19 PM
Hey ljung,
Yep tried both with and without.
Cheers
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-03-27
04:18 AM
2016-03-27
04:18 AM
Message 4 of 4
