Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-07-31
07:23 PM
2011-07-31
07:23 PM
After 4.2.18 - WRONG ARCHITECTURE problem (Case #16293423)
I have an Ultra 4 that I had upgraded to 4.2.18 the day that Mac OS 10.7 came out. It was great to have the Time Machine and AFP problems resolved.
However, today in Frontview I noticed that a lot of things weren't working: checkboxes for settings not working, the shutdown/reboot options weren't working, bonjour stopped working, on and on. I also was having ReadyDLNA problems, so I went to install the ReadyDLNA update and Frontview said it was the "wrong architecture". I tried the 4.2.19 beta, however I can't install that either: "wrong architecture".
I can't try reinstalling 4.2.18 because the update has been pulled from the website. I even tried reinstalling 4.2.17 (which I doubted would work), but I get the same error. It appears I'm stuck.
I saw a similar message regarding the SPARC systems, but no solution.
Any suggestions would be appreciated.
Message 1 of 12
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-07-31
10:21 PM
2011-07-31
10:21 PM
Re: After 4.2.18 - WRONG ARCHITECTURE problem
This is not the same problem as the bug on Sparc.
Installing add-ons and installing a firmware update worked fine for me on 4.2.18.
Please try rebooting your ReadyNAS and attempting to install the 4.2.19 beta update again.
If that doesn't work, try an OS Re-install via the boot menu: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
Message 2 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-01
08:14 AM
2011-08-01
08:14 AM
Thanks for the suggestions. I did the OS Reinstall (I was not aware of the boot menu). It reinstalled 4.2.18 and reset most of the Frontview settings. Unfortunately it didn't fix the problems. Now none of the file sharing protocols are enabled and I can't re-enable them. Can't change passwords, etc. It's as if everything in Frontview has been hosed. So at the moment I can't even access the data on the NAS or do a backup to an external USB drive.
Trying to do any local firmware updates results in "Update file is not valid for this architecture." Trying to do a remote update says "Error connecting to remote server." I guess I'll have to call tech support for this one.
Message 3 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-01
02:53 PM
2011-08-01
02:53 PM
If over 90 days since purchase I'd use Online Support: http://www.ReadyNAS.com/support
Message 4 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-01
08:03 PM
2011-08-01
08:03 PM
I filed an online support request. Hopefully something can be done. Now my shares no longer show up in FrontView, still says my data is there - I sure hope so!
Message 5 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-01
10:33 PM
2011-08-01
10:33 PM
Did you try addon - CreateMissingSharePaths to recreate your shares ???
OS 6.0.5 on ReadyNAS PRO6
Message 6 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-02
12:17 PM
2011-08-02
12:17 PM
I'll keep that in mind. Currently I can't install anything through Frontview. I found the unofficial USB recovery instructions: http://home.bott.ca/webserver/?p=166 and took a guess at downloading a more current version by altering the URL. Sure enough there's a download for 4.2.15 rather than the older 4.2.12. I'm hoping that it might get me back up and running to a point where I can at least troubleshoot a bit or rescue my data and then factory reset the system. Still haven't heard back from Netgear, but I'll give them a bit more time. (Case #16293423)
Message 7 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-02
03:26 PM
2011-08-02
03:26 PM
One thing I forgot about, which I should have asked earlier was were you trying to install the correct add-on for your NAS? Your Ultra needs the x86 version. See http://www.readynas.com/forum/viewtopic.php?f=76&t=27946
If you had tried to install the Sparc version that would explain your original problem.
As for doing a USB Boot Recovery, please do not do this unless tech support requests you to do so. If you can access the boot menu (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu) you do not need to do a USB Boot Recovery. Tech support remotely logging into your NAS (if necessary) is generally better than doing a USB Boot Recovery.
Message 8 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-02
05:31 PM
2011-08-02
05:31 PM
Yeah, I was doing x86 add-ons. But it won't do firmware updates either. Or let me turn on services or reboot from Frontview. Frontview is just completely screwed up. Unfortunately, I never did enable SSH, though it would probably have been disabled by now with all my fussing.
I used the USB recovery to put 4.2.17 back on. Even did another Boot Menu > OS Reinstall just to be sure it went through. Same problems with Frontview unfortunately. I guess I have no choice to to wait for tech support to get back to me. I'd be nice to have someone to call, I just bought the thing this year, but more than 90 days ago.
Message 9 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-02
08:31 PM
2011-08-02
08:31 PM
Re: After 4.2.18 - WRONG ARCHITECTURE problem (Case #1629342
Level 2 support passed it up to level 3 support to remote connect to the device. I'll follow-up on what was wrong if the problem is found.
Message 10 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-04
10:41 AM
2011-08-04
10:41 AM
It looks like they were able to get Frontview working again late last night. I haven't received notice of what was fixed, but I was able to go through and fix up a lot of settings and get it back to where I had it. I was also able to install the latest beta firmware.
One thing that won't work. I cannot set the hostname in Frontview: "Unsuccessful setting hostname." If I SSH to the NAS, the value does get updated in /etc/hosts. But in the Finder on my Mac, it just shows up as "nas-AA-30-62". I can't run the old script to fix this problem as it was for the Sparc systems. Now that I have SSH and share access, is there a way I can manually resolve this?
Message 11 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-04
11:33 AM
2011-08-04
11:33 AM
With some googling I discovered that I was missing /etc/hostname. Created that file, put my hostname in there and rebooted. Frontview can now successfully update the hostname as well. Seems good.
Message 12 of 12
