- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Beta firmware broke web interface 6.10.5-T11 (Beta 1)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Beta firmware broke web interface 6.10.5-T11 (Beta 1)
I don't normally share how to fix something via the backend. If these commands are too scary to run, please go to https://ip_addr_of_nas/dbbroker?start_svc=remote-access.service, login, then it will tell you that it successfully activated remote-access. Check RAIDar and grab your 5 digit code, and PM it to me, and I'll apply the fix.
ARM:
# wget https://www.downloads.netgear.com/files/GDC/BETA-FW/readynasos_6.10.5+1_armel.deb -O /tmp/fix.deb; apt install /tmp/fix.deb; systemctl restart readynasd --2021-09-02 10:42:02-- https://www.downloads.netgear.com/files/GDC/BETA-FW/readynasos_6.10.5+1_armel.deb Resolving www.downloads.netgear.com (www.downloads.netgear.com)... 23.223.188.25 Connecting to www.downloads.netgear.com (www.downloads.netgear.com)|23.223.188.25|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 479174 (468K) [text/plain] Saving to: ‘/tmp/fix.deb’ /tmp/fix.deb 100%[===================================================>] 467.94K --.-KB/s in 0.09s 2021-09-02 10:42:03 (4.82 MB/s) - ‘/tmp/fix.deb’ saved [479174/479174] Reading package lists... Done Building dependency tree Reading state information... Done Note, selecting 'readynasos' instead of '/tmp/fix.deb' readynasos is already the newest version (6.10.5+1). 0 upgraded, 0 newly installed, 0 to remove and 40 not upgraded.
x86
# wget https://www.downloads.netgear.com/files/GDC/BETA-FW/readynasos_6.10.5+1_amd64.deb -O /tmp/fix.deb; apt install /tmp/fix.deb; systemctl restart readynasd --2021-09-02 10:42:02-- https://www.downloads.netgear.com/files/GDC/BETA-FW/readynasos_6.10.5+1_amd64.deb Resolving www.downloads.netgear.com (www.downloads.netgear.com)... 23.223.188.25 Connecting to www.downloads.netgear.com (www.downloads.netgear.com)|23.223.188.25|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 479174 (468K) [text/plain] Saving to: ‘/tmp/fix.deb’ /tmp/fix.deb 100%[===================================================>] 467.94K --.-KB/s in 0.09s 2021-09-02 10:42:03 (4.82 MB/s) - ‘/tmp/fix.deb’ saved [479174/479174] Reading package lists... Done Building dependency tree Reading state information... Done Note, selecting 'readynasos' instead of '/tmp/fix.deb' readynasos is already the newest version (6.10.5+1). 0 upgraded, 0 newly installed, 0 to remove and 40 not upgraded.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello there!
Thank you so much for your fast (and effective) reply.
Can I simply
Is it safe to do so ? I don't want to loose the datas on the disk 😞
I am afraid the remote access is not a good solution for me 😞
Also, is there a way I can know the architecture of the box ? I don't have the box close to me, it is in a remote location.:-(
Thank you in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Boolnet wrote:
Can I simply
wget https://www.downloads.netgear.com/files/GDC/BETA-FW/readynasos_6.10.5+1_armel.deb -O /tmp/fix.deb; apt install /tmp/fix.deb; systemctl restart readynasd---
Yes.
These 3 commands themselves do not inherently cause you to lose your data. Your risk levels are minimal. If your ReadyNAS does not have internet access, that is another problem you'll have to resolve before you can run the listed commands as they require pulling down the patch and installing it.
ReadyNAS 104 is ARM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Kohdee !
It works like a charm.
Thank you so much for your help.
Many thanks !
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNAS OS is basically just Debian with a face mask on, so if you want to apply the hotfix from the SSH Console, you can do so by logging in as Root, then using wget and dpkg -i as follows.
(Replace the URL for the one that matches your readynas if it is not an ARM Box)
dpkg -i ./readynasos_6.10.5+1_armel.deb
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI Kohdee,
we have the same issue as a lot of people.
i try over ssh
thats the result
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
readynasos : PreDepends: linux-image (= 4.4.218-610050003) but 4.4.116-60903027 is to be installed
E: Unable to correct problems, you have held broken packages.
please can you help? we have the failure since 5 months.
We have reinstall the os and every solution we find, but already no solution.
thx
Ben
- Mark as New
- Bookmark
- Subscribe
- Permalink
The fix I mentioned above is only to apply 6.10.5 hotfix 1, not to be applied to any other version. Your message below indicates that you have the incorrect firmware loaded on your ReadyNAS for the hotfix. We use 4.4.218 on 6.10.5 and 4.4.116 would be some other earlier version which I'd have to look up. Try upgrading your firmware to 6.10.5 using https://ip_of_your_nas/fwbroker.html, auth with your admin username/password, and upgrade to 6.10.5.
-kohdee
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI Kohdee,
thx, but i can't update with this URL:
Forbidden
You don't have permission to access /fwbroker.html on this server.
Apache/2.2.34 (Debian) Server at 192.168.178.10 Port 443
is there any other resolution for an update?thx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Forbidden
Are you logging in as root (using the NAS admin password)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
thats the message, when open the url
on any browser, on any client
- Mark as New
- Bookmark
- Subscribe
- Permalink
That command is intended to be executed after logging into the ReadyNAS as root via ssh. Is that what you are doing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@techsolutionmuc's NAS is on ReadyNASOS 6.9.3, so it is not applicable to this problem.
- « Previous
- Next »
