- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
[Beta5] Time Machine failure on RN102
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
Since I updated my RN102 with the latest 6.4.0 Beta5, Time Machine always fails to comple a full backup on the remote location. Already tried to disable and enable timemachine on the NAS, also removed every folder from .timemachine folder.
It keeps giving me this error:
Meanwhile, I also have a timemachine backup on an external hard drive, and everything works great.
Can you please help me?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: [Beta5] Time Machine failure on RN102
Hello melojms,
Have you checked the connection between the Mac computer and the NAS via SMB and AFP? Are they stable?
What was the previous firmware version before updating to the BETA 5?
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi JennC,
Yes, at least SMB is working well (actually, sometimes it freezes).
Previously I had installed version 6.2.5.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have reproduced a problem copying large files using SMB from Windows and have a fix prepared for the next beta build. Perhaps there is a similar problem with SMB connections and Mac. This problem may not be specific to SMB connections.
As JennC mentioned Time Machine uses AFP. It would be interesting to see if you have problems with ordinary AFP file transfers.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure if this will help or not, but I was also having the same problem with Time Machine on OS X 10.10 on my RN104 with beta 5. From another thread I reverted to Beta 3 for issues of not being able to transfer large files to the NAS. After the downgrade to Beta 3, I have not had any more issues with Time Machine, however there is a performance hit that took place. But that also seems to be documented here already also.
For myself at least I was having problems with both AFP and SMB when transferring files on Beta 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have been struggling with those issues @JackDanl. Did the same thing than you. Reverted to Beta 3 and now is working ok. It happen too when the NAS is shutting down, sometimes it just turns off the disks but the LEDs continue to stay on. The power led flashes. I have to manually unplugged it from the wall.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you try Beta 6?
