× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
FW 6.9.0 OneDrive sync problem (RN204, RN104)
Kardano
Luminary
i have set to sync 4 dirs (not whole OneDrive) from my OneDrive account.
My dirs are synced OK.
When i set up for sync directory which is not my, but it is shared to my account from my friend's account with full (read/write) prermissions (and it is added as one of my shared dirs) it cannot sync.
In target dir on NAS is hidden dir (with numbers as name) created, but sync is not done. Not a file is synced.
When i set this dir to sync with OneDrive app, it is synced to PC OK.
Tested on RN104 and RN204 - with "bidirectional" and "download cloud storage changes only" mode - same result. Dir is not synced (downloaded)
Model: RN10400|ReadyNAS 100 Series 4-Bay (Diskless),RN20400|4BAY Diskless Desktop Readynas Storage
Message 1 of 13
Accepted Solutions
Skywalker
NETGEAR Expert
Re: FW 6.9.0 OneDrive sync problem (RN204, RN104)
Syncing of shared directories isn't currently supported.  We plan to add it in 6.9.1.
Message 4 of 13
All Replies
Marty_M
NETGEAR Employee Retired
Hello Kardano,
The OneDrive feature of the NAS would only sync with single OneDrive account. On your case I believe the NAS is behaving as normal. You have like a guest access provided on one of the folder from a different OneDrive account which you don't have access to the root directory.
Marty_M
NETGEAR Community Team
Message 2 of 13
Kardano
Luminary
Hello @Marty_M.
I have "guest" access with full permission (read/write), not read only.
Directory is mapped in my account shared folders. I see this dir (and NAS see it too) iin root directory od MY OneDrive account. OneDrive windows app shows this dir as "my"dir.
As show pisture above. Mentioned dir is "Vierinka" - 2nd from bottom of the picture.
NAS shows this dirs in root directory and CAN NOT sync them.
OneDrive app also shows dirs and offer/can (and do) sync of this dirs without any problems. i can donload, upload or delete from these dirs.
OneDrive app for Windows, same dirs - syncing:
Message 3 of 13
Skywalker
NETGEAR Expert
Message 4 of 13
Kardano
Luminary
Thanks for info.
Message 5 of 13
Kardano
Luminary
@Skywalker
If I may ask....
So...
IS syncing of dhared dirs supported with ReadyNASOS 6.9.1-T127 (Beta 1)? Was i added?
Thanks.
Message 6 of 13
Skywalker
NETGEAR Expert
No, unfortunately it's not there.  We use the OneDrive getChanges API to get notified of changes, but it does not send notifications for changes to shared folders.  We are inquiring with Microsoft to see if there is a way to do this.
Message 7 of 13
jdh2
Did the plans change? I have 6.9.1 installed now and shared folders are now sync'ing (still).
Thanks.
Message 8 of 13
Kardano
Luminary
Not syncing. This is about folders that rae shared TO YOU by someone else. Not Your shared folders.
Message 9 of 13
jdh2
Yes sorry for the type-o. That should have read: "Shared folders are NOT syncing (still)."
I am referring to shared folders that another person has shared with me, I selected to add to my own OneDrive. On Mac and Windows, those folders shared to me do sync down.  On readyNAS, they do not. It was reported to be planned for a fix in 6.9.1, but that fix does not appear to have gone in. I was inquiring when we actually will see that fix.
Thanks,
Jeff
Message 10 of 13
Skywalker
NETGEAR Expert
We had to release 6.9.1 sooner than originally planned to address some Samba vulnerabilities, so we weren't able to get this change in.  However, we do have an implementation for this feature that is currently being tested internally, and we expect it to be ready for 6.9.2 unless unexpected issues are discovered during testing.
Message 11 of 13
OOM-9
NETGEAR Expert
We have made the update for this support in the newer firmware 6.9.3.
It is currently available in beta at this time:
https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-9-3-T211-Beta-1/m-p/1493242
Message 12 of 13
Kardano
Luminary
tested on RN104. It is working. Thanks. Great.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 4968 views
  • 6 kudos
  • 5 in conversation
Announcements
