Reply
Highlighted
Fancontrol Questions Please
I have a PRO 6 running 6.1.2 and it's working perfectly EXCEPT I can't get my fans under control.
I have pasted my fancontrol file below and below that my current temps etc. I think I need the fans to be ideally around 1200-1400RPM to be quiet enough but I can't seem to make them operate at that level.
Fancontrol:
# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/w83627ehf.2576
DEVNAME=hwmon0=coretemp hwmon1=w83627dhg
FCTEMPS= hwmon1/device/pwm2=hwmon1/device/temp2_input hwmon1/device/pwm1=hwmon1/device/temp1_input
FCFANS= hwmon1/device/pwm2=hwmon1/device/fan2_input hwmon1/device/pwm1=hwmon1/device/fan1_input
MINTEMP= hwmon1/device/pwm2=30 hwmon1/device/pwm1=60
MAXTEMP= hwmon1/device/pwm2=60 hwmon1/device/pwm1=55
MINSTART= hwmon1/device/pwm2=70 hwmon1/device/pwm1=30
MINSTOP= hwmon1/device/pwm2=70 hwmon1/device/pwm1=30
MINPWM= hwmon1/device/pwm2=70 hwmon1/device/pwm1=30
MAXPWM= hwmon1/device/pwm2=200 hwmon1/device/pwm1=60
Sensors Output:
w83627dhg-isa-0a10
Adapter: ISA adapter
Vcore: +1.20 V (min = +0.00 V, max = +1.74 V)
in1: +1.76 V (min = +1.05 V, max = +0.78 V) ALARM
AVCC: +3.22 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.22 V (min = +2.98 V, max = +3.63 V)
in4: +1.24 V (min = +1.00 V, max = +1.65 V)
in5: +1.50 V (min = +1.15 V, max = +0.90 V) ALARM
in6: +1.03 V (min = +1.98 V, max = +0.27 V) ALARM
3VSB: +3.20 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.10 V (min = +2.70 V, max = +3.63 V)
fan1: 1739 RPM (min = 799 RPM, div = 8 )
fan2: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan3: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan4: 0 RPM (min = 5273 RPM, div = 128) ALARM
fan5: 0 RPM (min = 10546 RPM, div = 128) ALARM
temp1: +55.0°C (high = +127.0°C, hyst = +125.0°C) sensor = thermistor
temp2: +31.5°C (high = +80.0°C, hyst = +123.0°C) sensor = CPU diode
temp3: -1.5°C (high = +80.0°C, hyst = +123.0°C) sensor = thermistor
cpu0_vid: +0.000 V
Would someone be able to make a recommendation for me please? Also how alarmed should I be about the ALARMS word beside my voltages?
the Ambient temp in my room is about 23c
Message 1 of 2
Highlighted
Re: Fancontrol Questions Please
Really hoping someone can assist here please
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3637 views
  • 0 kudos
  • 1 in conversation
Announcements
