- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Help I got "ERR: Used disks Check RAIDar" With Beta 6.1.9
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Business Pro with 6.1.9 beta. It was working great for a few weeks but today it wouldn't shutdown properly and now it won't boot.
I get the above message on startup. I have tried to reinstall the OS from the boot menu but the error remains.
Anyone got any ideas? I really don't want to lose my 6TB of data.
I cant even SSH to it......
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Help I got "ERR: Used disks Check RAIDar" With Beta 6.1.
How many disks are there?
What does RAIDar say?
Presumably you did access the boot menu if you did the OS reinstall?
I take it you don't have a backup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Raidar just says the disks contain data and it gives the mac and IP address with a blue dot.
Boot menu works ok and yes my back is old....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your OS partition was full.
You had 2.5GB of Videos stored on the 4GB OS partition.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unit is both out of limited hardware warranty (by a few weeks) and running firmware that our support does not support running on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Our official policy is to not support running OS6 on legacy devices. Having said that I may offer to fix some issues if they arise.
I do recommend you keep up to date backups so you can do a factory reset and restore your data from backup (if necessary).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have a PC with enough bays, you can also do a backup to the PC over the network. I use that to make a second backup (using robocopy).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having this same experience on a Pro Pioneer running OS 6.2.4.
I've been running plex for several weeks but recently the plex service became unresponsive and the NAS seemed to freeze during reboot as it never powered off. Upon manually pulling power and booting, the following error was displayed on the LCD: "ERR: Used disks Check RAIDar". I'm now unable to ssh into the nas to troubleshoot the system. I attempted an "OS Reinstall" from the front panel but this had no effect on the symptom. I've also entered 'Tech Support Mode' in the hopes that this would allow me to ssh into the system but this did not work either.
I'm not certain my issue is the same as the OP's as all of the libraries I've assigned to plex are located on my personal data shares. Though perhaps since plex is itself installed on the OS partition, it is caching data to it's directory on the OS partition and filling the partition.
Any idea how I may gain access to the NAS to kill the plex directory?
