× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
*OLD* ReadyNASOS 6.9.3-RC2 *OLD*
OOM-9
NETGEAR Expert
 Latest beta: ReadyNASOS 6.9.3-RC2
• ARM (102 / 104 / 2120 / 202 / 204 / 212 / 214)
• x86_64 (312 / 314 / 316 / 422 / 424 / 516 / 524 / 526 / 528 / 626 / 628 / 716 / 3130 / 3220 / 3312 /...
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
Changelog
  1. [Beta 1] AFP is defaulted to disabled on newly formatted units
  2. [Beta 1] Added some tool tips around volume status icons
  3. [Beta 1] ReadyTIER status under the volume settings
  4. [Beta 1] Remove RAID Group option for volumes with multiple RAID Groups
  5. [Beta 1] Initiate a Test Disk volume option
  6. [Beta 1] TiVo Server “fast transport” option for newer TiVo Device compatibility
  7. [Beta 1] Added per share Auto-Defrag
  8. [Beta 1] Added per share SMB strict sync
  9. [Beta 1] Home Folders support SMB3 Transport Encryption
  10. [Beta 1] Time Machine over SMB support
  11. [Beta 1] Backup job progress is available under status information
  12. [Beta 1] Initial backup job creation allows to discover local devices
  13. [Beta 1] Initial backup job creation allows to browse the share/folders on remote device
  14. [Beta 1] ReadyDR option to send email alerts for successfully completed backups
  15. [Beta 1] Wasabi cloud service support
  16. [Beta 1] Amazon S3 China and custom URL support
  17. [Beta 1] OneDrive now supports syncing with (OneDrive) shared folders
  18. [Beta 1] Cloud services displays status of Enabled/Healthy, Syncing, Failed or Disabled
  19. [Beta 1] Cloud services displays the signed in account for the registered cloud service
  20. [Beta 1] Cloud services display the space consumed and available
  21. [Beta 1] Cloud services can be enabled/disabled without having to leaving the cloud service
  22. [Beta 1] Fixed some cases where FTP folder name would display incorrectly
  23. [Beta 1] Admin interface Logout button
  24. [Beta 1] Admin interface session timeout
  25. [Beta 1] Safe mode to help provide access to the NAS when there are no disks, used disks, and cases where there are issues with the OS partition. This newer functionality will help provide support, debug and alternative data access options that was not available in the past.
  26. [Beta 2]Fix in some cases where one email recipient would get any email out of many email recipients
  27. [Beta 2] Uptime is now displayed on overview page
  28. [Beta 2] Fix in cloud syncing for some files that require charactors to be escaped
  29. [Beta 2] TiVo Fast Transport tooltip
  30. [Beta 2] Fixed ReadyCLOUD from earlier beta verion
  31. [Beta 2] Fixed AV to prevent strange behavior
  32. [Beta 2] Insight has been removed, but service is still available through ReadyCLOUD at this time.
  33. [Beta 2] Rsync over SSH now has the improvements to initial backup.
  34. [RC1] Fixed the Uptime calculation fix
  35. [RC1] Fixed the AV pattern update
  36. [RC1] AV now reports the virus blocked from backup jobs
  37. [RC1] Corrected the capacity size for Time Machine over SMB
  38. [RC2] Fix for the AV caused issues on the OS
  39. [RC2] Fix for cloud services where sync was getting rate limited
  40. [RC2] Fix for OneDrive Business accounts (since business accounts don't support Shared Folders)
  41. [RC2] Security update to the kernel
  42. [RC2] Check for Updates now sees RC newer as a newer version than Beta
WARNINGS:
  • Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
  • Devices updated with 6.9.3 firmware should not be downgraded to firmware versions before 6.9.0.
  • ReadyNAS 102, 104, and 2120 must not be updated directly to 6.9.x from 6.3.x or older firmware.  They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.9.x.
  • ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.9.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.9.x.
KNOWN ISSUES:
  • None.
Message 1 of 4
OOM-9
NETGEAR Expert
Re: ReadyNASOS 6.9.3-T211 (Beta 2)
Posted Beta 2.
Message 2 of 4
OOM-9
NETGEAR Expert
Re: ReadyNASOS 6.9.3-RC1
Posted RC1.
Message 3 of 4
OOM-9
NETGEAR Expert
Re: ReadyNASOS 6.9.3-RC2
Posted RC2.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 6839 views
  • 1 kudo
  • 1 in conversation
Announcements
